Eleven Rack Clean distortion
I have been using my 11R for a month or so now, and I have made some great (to me at least) distortion sounds. I play heavy metal and they do a perfect job.
The only trouble I am having is finding a decent clean tone. Every time I find a clean tone, the input overloads and it distorts the tone. I have looked for a pad switch or option but I cannot seem to find one. Anyone have any pointers? |
Re: Eleven Rack Clean distortion
hit the edit button, scroll to the amp and check your amp out volume (reduce as necessary).
scroll to end and check the level meters at main outputs & rig outputs (whats the difference -- not sure off the top of my head) I was getting the same clipping myself until I did this, I find that the volume I can get on clean patches is a fair bit less than on the heavy patches though unless I add a compressor to the clean chain, maybe something to do with the compression that distortion naturally brings. |
I will have to give that a try. I checked the output and input meters and they weren't peaking, but I didn't think about the amp modeling. Thanks for the help!
You can also try downloading presets made by other people then tweak them (if need be)
Tons of presets at http://www.elevenrackpresets.com/ and http://elevenrackusers.blogspot.com/
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I don't actually have a DAW yet. Using the 11R for live sounds. I will definitely give them a look when I get Protools thought! Thanks for the help
Try backing your volume knobs on guitar off a bit too....you may be surprised at how it sounds.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Pro Tools 8 Distortion Playback Eleven Rack | kll | Windows | 1 | 10-20-2012 09:23 PM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Clean sound over distortion | jevolent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-02-2012 04:30 PM |
Crackling and/or audible artifacts w/ Eleven Rack clean tones? | wildstar | Eleven Rack | 50 | 02-23-2012 04:12 AM |
clean up heavy distortion | c-post | Tips & Tricks | 11 | 03-26-2002 08:38 AM |
