Unable to install c8 drivers.......
I DOWNLOADED THE COMMAND 8 SETUP SOFTWARE FROM THE DIGIDESIGN WEBSITE AND MY PROTOOLS STILL WON'T RECOGNIZE MY COMMAND 8. IT POWERS UP & THE FADERS DO THEIR TEST (UP & DOWN) THEN IT CLICKS AND THE SCREEN READS COMMAND|8 (OFFLINE) HOW DO I FIX THIS? I'VE TRIED EVERY SUGGESTION ON HERE AND NOTHING IS WORKING.
Re: Unable to install c8 drivers.......
Hey ginoworld,
Did you find a solution to this problem? I am experiencing something similar with the 8.0.1 upgrade. If you have any tips or advice, please share! Thanks! |
What suggestions have you tried, exactly?
Did you configure it properly in Setups>Peripherals>MIDI Controllers? Can you tell me the settings you're using in that window? |
Does anyone know if the C8 is compatible with snow leopard and pt 8.0.3, i'm having the same offline issue and message.
"protools unable to communicate with command|8. Power cycle and check its connections." Sorry my settings in peripherals are: type receive from send to C8 C8,port 1 C8,port 2 Last edited by BkCitrus; 11-02-2009 at 01:28 PM. Reason: i did not specify my settings |
My command 8 is working perfectly with snow leopard and PT 8.0.3
Unable to Re-Install 002 & 003 Drivers | Bryn772 | macOS | 1 | 07-20-2012 03:03 PM |
Install HD drivers? | Boe Larsen | Pro Tools TDM Systems (Mac) | 2 | 01-08-2011 01:58 AM |
Why install Pro-Tools to install drivers for Mbox2 | bigbobbysd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2010 07:42 AM |
Should I install PT 8 before or after I plug in my 002r that will install drivers? | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-05-2009 10:12 AM |
Unable to Install and now Unable to Uninstall | Blueear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-14-2006 08:17 PM |
