Old 10-29-2006, 09:37 PM
thirdeyebling thirdeyebling is offline
Default turntable to computer using an m box 2 pro
hi,
i gotta question i really need help with. i recently purchased a mac
pro....if anybody has the knowledge please let me know.... i've hooked up
my turntable up to an m box 2 pro which does have a pre amp on it. i
get a reading of sound from the system prferences/sound in my mac, and i
have selected m box pro for both ins and outs of there. now my question
is, why can't i here any sound from my pro tools when i load it? or
from my computer at all for that matter? please help if you can out there.
i'd be extremely grateful. peace
Old 10-30-2006, 01:57 AM
comprodman's Avatar
comprodman comprodman is offline
Default Re: turntable to computer using an m box 2 pro
for a record deck you need a phono input. It is a completely differnt impeadence to line in. Line in only gives you a 20db gain and phono is an 80db boost I think. Thats why you can't hear it.
Pro Tools Editor, Producer, Mixer and Masterer since 1998
Old 10-30-2006, 02:03 AM
audiaudio audiaudio is offline
turntable > phono pre amp > m-box line in
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 10-30-2006, 07:30 AM
albee1952 albee1952 is online now
GUys, Mbox2 PRO has a set of RCA inputs for turntables. I suspect operator error here. Review the manual and try to find DIGIFLIX as they have some great tutorial videos to get a newbie up and running.
Old 10-30-2006, 07:32 AM
pk_hat pk_hat is offline
Well, the mbox2 Pro already has phono inputs ready to go, meaning you shouldn't need another 'phono preamp' between the deck and the mbox. All this info should be in your manual or getting started guide. If you plan on using the main pres or line level inputs then yes, you will need the little black box (phono pre) between turntable and interface.
www.myspace.com/krou
Old 10-30-2006, 10:59 AM
well, i've looked at my manual again, not that i haven't quite a number of times before, but nothing i have did is wrong in this situation. like i said before, i do get a reading showing my computer is registering it (and i have my m box 2 pro selected as my main audio in's and out's, but no sound. please help. thanks a lot guys
thirdeye
Old 10-30-2006, 11:00 AM
comprodman's Avatar
I bet you will find that the phono inputs on an MBox2 are balanced inputs for a tape deck, minidisk player or CD player so will be at +20db and not for a record deck which needs +80db which I said earlier. Because if you plug a CD player into one that is set for a record deck it would flat top and Digi would get 1000's of complaints everyday.
Old 10-30-2006, 11:26 AM
Starcrash Starcrash is offline
comprodman,
Maybe you should review the specs on the MBox 2 Pro and get back to us. You'll notice that it has a separate phono (turntable) input complete with ground. This is a new feature.
thirdeyebling,
Have you assigned the input in the mixer window? I haven't used the MBox 2 Pro, but I imagine that there is a different input setting for the phono input. The default input is Analog 1. Someone who has experience with this interface should chime in.
Pascal Garneau | IMDb
Old 10-30-2006, 01:05 PM
jeffro's Avatar
jeffro jeffro is offline
Do you have the Source Selector for the Aux In set to Phono? (Front panel button to the left of Input 1 should be pushed in.)
What inputs are you selecting on your tracks in Pro Tools LE? (Should be Inputs 3&4.)
Have you turned up the Aux Input Gain knob?
P.S. The Phono inputs on the Mbox 2 Pro are indeed phono level inputs.
linkedin
Old 10-31-2006, 08:59 PM
thank you guys mucho. for sure! i got pro tools up and working now, i had the inputs right, but the i/o settings where not (analog 3-4 for the top input, right input needed to have mic/line, then 3-4, if that makes any sense, probably not, but you guys where a big help. peace.
Pro turntable into 003 lfpillay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2012 08:38 AM
re: turntable to pro tools 2224 Pro Tools 9 4 07-16-2012 10:51 AM
Turntable to 003 Grant26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-15-2012 11:04 AM
USB Turntable jlnelson19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-11-2009 02:13 PM
Turntable FX in PT 8 Digital Network Tips & Tricks 6 03-11-2009 09:57 AM
