Pro Tools connected to WiFi without internet
Hello all
I’m running ProTools Studio on Mac OS Ventura. The computer is connected to a WiFi router that has no internet connection. Reason being all S1 tablets connect to this router. Pro Tools takes forever to start up and load a session when connected to WiFi and no internet. I assume it sees the WiFi connection and looks for cloud based licenses. All licenses are on an lLok in my case. Any idea how to speed up the startup process? I tried little snitch but I guess I’m not smart enough to set it up correctly. Thanks |
Re: Pro Tools connected to WiFi without internet
Hi, welcome to the community. Please take a look at Help Us Help You page that is linked to the forum header.
Hi welcome to DUC.
Since there is not a lot of useful details given here I am going to guess that the Pro Tools icon is likely bouncing in the dock. If so then the Mac thinks there is a network route to the Internet where it can reach the ocsp.apple.com certificate revocation servers and not doing so it will eventually time out. I and others have posted about this on DUC many times in the past, so I would have hoped that would have been findable in a google search... but maybe not so easy. If so, you need to setup your local network correctly. You can use static or dhcp addresses, set up a local network DNS name server if you want to. But the network must not imply it has a route to the Internet.... why are you using a *router* if it does not? ... that is the job of a router. You can either configure the router properly and delete the route info on the Mac it would have been given by the router or maybe get a WiFi hub and configure the Mac to be a DHCP server if needed. Nothing here is really Pro Tools or Avid specific, and if this does look like the issue you can Google for "ocsp.apple.com" or Apple certificate revocation etc. to find out more info if you want. Last edited by Darryl Ramm; 02-03-2024 at 02:45 PM. |
And I could actually give you the commands to do this. But DUC is so farked up that you can't post oh actual useful technical command line things in an easy to use way... on a technical forum.
But here is it in PITA, unfriendly (and maybe less security conscious) PDF. Maybe useful for folks who want to learn some network setup stuff, including by reading the UNIX man pages for these commands (e.g. $ man networksetup). The point is to make sure the Mac knows there is no route to the Apple revocation servers, so it does not try, and hang for a while waiting... Last edited by Darryl Ramm; 02-03-2024 at 07:38 PM. |
Code:
Use the code tag, which looks like hashtag.
And? tagging stuff as CODE does nothing useful here. But uh thanks for explaining VBulletin syntax to me, after nearly 20,000 posts here and a few years helping run other vBulletin servers... ¯\_(ツ)_/¯
DUC is broken, screwed up, with a poorly run WAP filter that stops lots of content being posted that looks like useful UNIX admin commands. This has been covered here in many many threads, many of which you have been on. I identified that original problem to Avid, explained it multiple times, pointed out lots of cases, and it's still so broken. |
Point taken
Pro Tools Plugins Only Work When Connected To Internet | Brightshine | Licensing & Accounts | 4 | 10-14-2023 06:59 AM |
Dock & S3 (ethernet) / iPad & Internet (WiFi) Connectivity Problems | freeBase | Avid S1, S3, Dock and Control App | 4 | 11-04-2022 01:44 PM |
Do I need to be connected to the internet to use PT? | PihSant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-04-2010 11:59 AM |
Anyone Using PTools While Connected to Internet? | tomhartman | Pro Tools TDM Systems (Mac) | 9 | 07-08-2003 12:55 AM |
Wanna upgrade to Q-Time PRO, but system is not connected to the internet... | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-22-2003 02:34 AM |
