Old 05-03-2004, 08:21 PM
zepp9 zepp9 is offline
Default Asus K8V Models- K8V- K8V Deluxe - K8V deluxe SE
Hi, I was wondering if it was possible to use any of the Asus K8V Models for the Allenstein AMD 64 machine and if so what the differences were. I researched all three but I'm not really a motherboard guy so I didn't quite understand the differences, any clarification would be greatly appreciated, Thanks, Zepp9
Old 05-03-2004, 08:35 PM
Allen Hallada Allen Hallada is offline
Default Re: Asus K8V Models- K8V- K8V Deluxe - K8V deluxe SE
Zepp, your not alone. It is mostly small changes that don't seem to affect PTLE performance. Things like the type of ethernet chip used etc. Check the reviews at Newegg to be sure there aren't problems with any of them.
Allen
Old 05-04-2004, 03:43 AM
Thanks Allen, I will do that. The last time I built the Allenstein machine I used the FIC AU13 instead of the A7V600 (which is sitting in my Apt. still new) and it worked perfectly minus 2 AUX tracks with the DaveC test, but it ran 3 degrees celsius cooler, I might just bite the bullet with the FIC K8T800 which is half the price of the K8V and post the results.
Old 05-04-2004, 07:25 AM
Bigpit Bigpit is offline
I have the k8v deluxe motherboard, and Im using the AMD Athlon 64 3200+ prosessor. I have 1024 MB ram and a 200 GB HD. It works fine, on win XP home edition. I just have one problem. The digidesign compressor makes a loud noise sometimes, when I close the compressor everything is OK again. That's my only thing, for now....
http://www.angelfire.com/music5/bigpit/songs
Protools 9, digi 002 rack.
CPU: Core i5 760
RAM: Lynnfield, 4GB DDR3, P55-chipset, LGA 1156
Cooler: Master CM 690 II Advanced Sort
Graphic: XFX Radeon HD 5870 1GB GDDR5
System HD: Crucial RealSSD C300 2,5" 64GB
Storage HD: 500 GB
External HD: 500 GB
Op system: Microsoft Windows 7 Home Premium NO
OEM, 64bit
Old 05-04-2004, 07:27 AM
BTW, the protools le test. You know.. whre u use several plugins on 1 track and copy it til the CPU goes red. I can run all tracks. (32 tracks) On Green
CPU: Core i5 760
Storage HD: 500 GB
External HD: 500 GB
OEM, 64bit
Old 05-04-2004, 07:29 AM
http://www.angelfire.com/music5/bigpit/Songs.htm
CPU: Core i5 760
Storage HD: 500 GB
External HD: 500 GB
OEM, 64bit
Old 05-04-2004, 08:34 AM
JamesV JamesV is offline
K8V stripped version should work fine. K8V deluxe which most of us are using is great choice, includes fast Gigibit LAN. K8V deluxe SE, "second edition" is the newest out, but for some reason includes slower Ethernet LAN.
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al
eSATA with ASUS P5K Deluxe ? VanDerGraf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-02-2011 08:40 PM
ASUS P5W DH Deluxe AlphaDingo Pro Tools TDM Systems (Win) 2 11-17-2010 09:13 AM
Max CPU Speed in an Asus K8V-SE Deluxe? shipwrecked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-15-2006 05:01 AM
Asus K8V SE Deluxe - Need to buy 2 x 1 gig Tracy Lowery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2006 06:36 AM
REGARDING THE ASUS K8V SE DELUXE AND RAM glu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-19-2005 08:51 PM
