8.01 Playback with Video issue.....
Not sure if this is in any way related to the 8.0.3 bug in the other threads, but was wondering if anyone else had experienced the following.
When playing back video, either in the video window, or out of a decoding card (Blackmagic Intensity Pro in this case) there is a long pause before it starts to play. I can scrub through the video fine with no problems, but as soon as i hit play i get this long pause. There is no stutter or crash as per problems with 8.0.3. I've started a new session running just the video track to test that it's nothing to do with heavy sessions. Once I turn the video track offline, it runs perfectly. Any ideas? System Spec as follows Intel Mac v. 10.5.8 2 x 2.66 Dual Core Intel Xeon 4gb ram PTLE 8.0.1 Hardware 003 Video Card - Blackmagic Intensity Pro DVToolkit 2 Thanks |
Re: 8.01 Playback with Video issue.....
I have seen the same thing when alt-tabbing out of PT to browse files or folders.
After spotting a file into the timeline, I come back and hit play sometimes the long pause happens. I figure its a lack of ram? I only have 6 gigs on my 8 core MacPro at this time. |
Just played the file in Quicktime itself, and the exact same time delay. So probably something to do with this. One thing I'm thinking though is that if that's the case I shouldn't have to have a bucketload of RAM just to play back video without delay. Will check with lower res files to see if it makes a difference!
ok so having played a number of different formats including
DV-Pal mov extension DV-PAL dv extension h.264 Photo JPEG I get exactly the same delay time whatever the file size, so surely if it was RAM then it would be a slightly different time per codec??? |
Urgh, ok solved - The solution = Corea audio problem.
I had my hardware on before computer boot, automatically starting Corea audio. Once I then start pro tools the core audo seemed to become confused. The solution - turn the hardware on after the computer boots! |
or set the sound output and input to anything but digi hardware. known issue since the 7 days, and thats digis fix
- Ando 003 / ADA8000 iMac 24 2.33ghz / 3gb Ram OS X 10.6.2 Pro Tools LE 8.01CS1 DVTK2 LOGIC 9.1.1 |
haha! soz my bad
Video playback issue | dino_squirrel | Pro Tools 10 | 1 | 08-17-2012 08:34 AM |
AVID video engine playback issue | Audio_Vision | Pro Tools TDM Systems (Win) | 4 | 04-08-2011 01:09 PM |
Small video playback issue | Meads | Pro Tools 9 | 2 | 11-28-2010 08:55 AM |
003 rack issue with video playback in PT LE 8 | sguy006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-21-2009 01:28 PM |
Video playback / priority issue... | komakaze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 06-18-2009 07:50 PM |
