Old 11-18-2001, 05:44 PM
stevemusic stevemusic is offline
Default Upgrading Toolbox
Can I use a Rosetta AD as the front end of an Audiomedia III/ Protools LE system?
Would I connect the spdf out of the Rosetta to the spdf in of the AMIII card and then select spdf input on the track to be recorded on? If so, would that increase the A to D conversion from 18bit (AMIII) to 24bit (Rosetta) only in a 24 bit session? Since I use a lot of CD audio (which is 16 bit) I have been using 16 bit sessions because you cannot import CD audio into a 24 bit session? Would the Apogee improve the A to D conversion in a 16 bit session?
null
Old 11-18-2001, 07:08 PM
Sugarite Sugarite is offline
Default Re: Upgrading Toolbox
The AMIII should be able to handle the 24-bit 44.1kHz or 48kHz output of a Rosetta a/d, connected as you've described. However, you might consider the Lucid AD2496, substantially cheaper, and a respected performer.
Toolbox 2 / Structure manicdown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-04-2009 09:37 AM
ToolBox XP adrock337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-29-2005 06:04 PM
Toolbox CD? mic check 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2001 12:07 AM
Toolbox confusion with TDM ? Pat Hannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-29-2001 09:40 AM
HELP, OLD TOOLBOX!!!!!!!!!!!!!!!!!!!!!!! patrickb Pro Tools TDM Systems (Mac) 0 06-04-2000 05:35 PM
