Old 06-04-2019, 06:22 PM
fsavell fsavell is offline
Default 2019.5 and CPU Usage
I'm running HDX2 and MacPro 5,1
I upgraded to 2019.5, first with Mojave, and then I downgraded to High Sierra, to check which OS behave best. FWIW can't really fault either except for the below.
On both OS I'm seeing strange CPU readouts. Essentially I have big mixes that are pinning the Total CPU meter to 100%, flat out red the entire time, yet my mix is still playing without any error. Activity monitor shows only 45-50% of CPU being used during these sessions.
Normally if I hit 100% CPU on previous versions of PT, it would instantly throw a playback error -90xx
Is anyone else seeing strange CPU readouts after upgrading to 2019.5.
Forrester
Old 06-04-2019, 07:41 PM
BScout BScout is offline
Default Re: 2019.5 and CPU Usage
In the release notes for 2019.5, they mention they re-wrote how the CPU usage is shown in Pro Tools.
So you are just seeing a "new" representation of CPU usage. What goes on behind the scenes is still the same.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-04-2019, 10:11 PM
Cool, thanks for the info. Seems like a strange way to go about it. I find the CPU usage to be less informative now. Wondering if its a weird quirk with my system or its standard fare for everyone.
Old 06-05-2019, 11:47 AM
the.engineer the.engineer is offline
Forrester
+1 here too
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Old 06-06-2019, 12:57 PM
For me(on Windows 10 PC), 2019.5 has resulted in a much smaller change in cpu between 64 and 1024 buffer settings, and I am now able to do things at the 64 buffer that never would have worked before without playback stops and/or error(9xxx). So far, very happy here
Old 06-06-2019, 02:37 PM
arche3's Avatar
arche3 arche3 is offline
Mac high Sierra. Much better CPU utilisation for me. Hdx. Mac pro 51
Sent from my SM-G975U using Tapatalk
Old 06-06-2019, 03:17 PM
AlexLakis AlexLakis is offline
I've found the same on the Mac side. Today I recorded 12 tracks (drums) over top ~30 tracks with VMR and DMG on every track, a couple VIs, 4 headphone sends on every track, verb/delay all at 96k on a buffer size of 64. 2018 Mac Mini, 10.4.5, 2019.5, Slate VRS8 x2. Everything was snappy, could add vmr modules/tweak while recording, browse the DUC, etc.. 2019.5 has been a winner for me!
Old 06-07-2019, 09:36 AM
seanmccoy seanmccoy is offline
Similar experience here. When working really fast on a moderately heavy 5.1 video project I will get occasional audio or video errors while working at 64. Upping it even to 256 eliminates all issues. 2019.5 is definitely a more efficient animal.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.6, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Quad; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.6, Apogee Rosetta 800, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Sierra, MOTU LP32, Pro Tools 2018.3
Old 06-12-2019, 12:41 AM
the19thbear the19thbear is online now
How do you really read the cpu meter now? It doenst really make sense to me.
On the positive side, PT has NEVER been able to have such a low buffer as it has now. I'm getting much more out of my CPU since the newest PT version.
Old 06-13-2019, 07:04 AM
eledu eledu is offline
Nice! The re-wrote it to be an useless meter??
.eledu.
CPU usage different with 2019.5? justinhill Pro Tools 2019 24 05-10-2019 03:20 AM
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
