Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-11-2019, 12:19 PM
bashville bashville is offline
Default Weird quantize result? Midi in sample mode
Yes I'd normally be in tick mode, but shouldn't it work anyway? I selected some midi notes of a track in the piano roll, went to quantize them, and voila all the other notes disappeared! (And no they're not in the region beyond that in the timeline). If it's just not allowed in that mode, then how about a warning saying so?
HD Ultimate (HD Native), PT2019.12, OWC PCI-ext. TB2, Blue 192, 2018 MacBook Pro, 32 Gig, Mojave 10.14.6
Old 04-11-2019, 03:08 PM
Default Re: Weird quantize result? Midi in sample mode
hmm OK not just quantizing; moving any notes within a clip independently from the other notes wipes all the other notes. You can slide the whole clip around on the timeline, but basically don't mess with the contents! Same result even just muting or deleting a single note. (with midi track in sample mode)
Old 04-11-2019, 03:25 PM
ZEUSS ZEUSS is offline
It’s a known bug. Consolidate the midi and make a new clip. Then it should work. Although I have seen it come back even after consolidating sometimes and I just repeat the process.
10.14.6 Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2020.5
Macbook Pro, 2019 (15,1) 32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2020.5, Apollo 8 Silver
Old 04-11-2019, 04:01 PM
Thanks--there's no problem now actually switching it over to tics. Was just definitely an odd result
weird Quantize behavior MilesMusic Pro Tools TDM Systems (Mac) 1 06-27-2006 02:30 PM
MIDI-volume edits result in hard crash... Arno Peeters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2006 03:24 AM
PT7 weird quantize issue RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2006 02:11 PM
Weird stuff on quantize with Mach 5 RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2005 07:16 AM
Weird Sample Rate Problem JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-07-2004 10:22 PM
