Old 01-08-2016, 10:45 AM
Marsdy Marsdy is offline
Default S6 XMON standalone use
Can the S6 XMON be used standalone without an actual S6 being connected?
Please bear in mind I don't have my S6 actually up and running yet.
I've tried but can't seem to get any output through any of the three speaker outputs? The MIDI LED is showing activity on the XMON whenever I move a fader or click something in the XMON app.
Dave Marsden
UK
Old 01-08-2016, 04:46 PM
Avid Pro Mixing Support's Avatar
Avid Pro Mixing Support Avid Pro Mixing Support is offline
Default Re: S6 XMON standalone use
You should be able to use it without the S6 connected. The functionality is limited though, so you will need to make sure the audio routing is set the way you want it (speakers mutes are off, input paths routed) before disconnecting the S6.
-Rich
Old 01-08-2016, 07:13 PM
EddieJones's Avatar
I think they come with the individual speakers cut by default and I'm not sure you can un cut them with the App alone. There is a pref file on the workstation that stores this info that can be edited to un cut but I won't be able to find out the specifics till Monday now.
Old 01-09-2016, 03:12 AM
Thanks Eddie and Rich.
Yes the speaker outputs are cut by default but it appears you can un cut them from the XMON app. When launching the XMON app the master mute button on the XMON hardware un-mutes automatically. There is 30dB of gain above 0dB on the speaker output fader in the XMON app. If you turn that all the way up there is noticeable hiss coming from the XMON. Not surprising with that amount of gain above 0dB! (I tried this with my Mixcubes, I'd rather blow them up than my ATCs!!!!!)
So... My inclination is... audio is getting from the XMON speaker outputs to the speakers but audio from the XMON inputs, i.e. the Pro Tools interface output is NOT being passed to the speaker outputs by default in standalone mode. There is no way of adjusting the routing of the Pro Tools input to the speakers in the XMON app, just a switch to swap between mono and 7.1. Neither work. I'm working in stereo and realise that the right side output of the XMON is on connection five of the D-Sub speaker outputs but I'm not even hearing anything from output one, the left side.
Dave Marsden
UK
Old 01-09-2016, 08:35 AM
EddieJones's Avatar
I'm talking about individual speaker cuts (Left, Center, Right etc.) Also you are probably right about the sources not being routed, this is also set in S6.
Old 01-09-2016, 10:44 AM
OK Thanks Eddie. It looks like the XMON can't be used standalone.
Dave Marsden
UK
Old 01-10-2016, 11:29 PM
RichN's Avatar
RichN RichN is offline
Hi Marsdy,
If you want to control your XMON independently from the S6, you can connect a 3rd party hardware controller like the Colin Broad TMC1
http://www.colinbroad.com/cbsoft/tmc1/tmc1.html
Rich Nevens
Director WW Strategic Audio Sales
Old 01-11-2016, 02:10 AM
Originally Posted by RichN View Post
Hi Marsdy,
Hi Rich
That's looks great but I just need a temporary solution. I'm without a functioning Master Module at the moment.
Feature Suggestion: Could you guys add functionality to the XMON App so the XMON can be used standalone. Let's say your Master Module dies on a Friday too late for a replacement to ship out that day. The earliest a replacement can be shipped out is Monday then you have to wait for delivery. At least if the XMON App had full or at least some monitor section functionality, you could still get audio out of Pro Tools to your speakers.
Dave Marsden
UK
Old 01-11-2016, 04:01 PM
priorytools priorytools is offline
Get on a bus, or train.
Find a seat.
Sit down.
Put xmon on floor at your feet.
At the next station, leave bus or train without picking up xmon.
Sorted.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-12-2016, 02:06 AM
Find a seat.
Sit down.
Sorted.
Dave Marsden
UK
Old XMon on S6? paulo m Avid S4/S6 15 08-20-2014 03:22 AM
Need XMON help AINSLIE ICON & C|24 9 05-31-2012 11:51 PM
Xmon?? bstroner ICON & C|24 5 04-01-2009 05:47 PM
XMON for your DAW Mike Landolt General Discussion 1 04-13-2006 03:04 PM
XMON tstemland ICON & C|24 2 03-23-2006 02:00 PM
