Trial version of PT10.2?
Today I downloaded and started using the trial version of PT 10, which is v10.0.0.
I was wondering - is there any way to demo 10.2? I'm keen to check out the bugfixes.
Sound design, audio editing, and instrument programming for Kontakt and MachFive http://www.iainmorland.net |
Re: Trial version of PT10.2?
Connect to the internet, open Pro Tools and tell it to check for updates. That may work. Are you suffering any bad issues with 10.0? I had no major issues with either 10 or 10.1.2. Only reason I even tried 10.2 was because I can revert easily as I save drive images at each stage.
In the mean time you can read about the bug fixes in 10.2 here.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Thanks - the main thing I wanted to test is problems with occasionally silent tracks (which should be playing) and distorted noise during the playback of fades - both of which have happened apparently randomly with 9.0.6.
The in-program updater told me that 10.0.0 was out of date but didn't appear to offer an update. However, I've now found the 10.2 download links at the bottom of this page - http://avid.force.com/pkb/articles/d...ls-10-2-Update - so will try those.
Quick update - in case anyone else is looking for this info - yes, it's fine to install the 10.2 update (since it's a full installer, you need to remove 10.0.0 first) and run it from the 30-day trial license.
Edit: although I do now get a '403 - Forbidden: Access is denied' message when I open the help browser from within Pro Tools. Hmph. Edit again: fixed the 403 error by going to the 'marketplace' page and logging into my Avid account, then reopening Help.
PTMP9 -> PT10 Trial | Perfect 5th | Pro Tools M-Powered (Mac) | 0 | 05-23-2013 01:52 PM |
HELP! PT10 Opening new version session in older version | Claudiu | Pro Tools 10 | 6 | 11-04-2012 03:32 PM |
How to start trial PT10 HD? | dr_pavlic | macOS | 0 | 09-30-2012 01:07 AM |
No Waves V9 in PT10 Trial | eveaudio | macOS | 3 | 06-10-2012 08:16 PM |
PT10 trial | Jim Morris | Pro Tools 10 | 2 | 01-11-2012 02:16 PM |
