Old 09-10-2018, 06:52 PM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Default Digi PRE (Blue) no longer talking to ProTools
Running PT Ultimate, 2018.7, see other specs below.
Somewhere between 2018.4 and .7, my trusty Digi PRE stopped playing nice with ProTools. It's partially there: it appears in the I/O window, the Mic Preamps window, has a positive connection in the Audio/Midi OS app, but Mic Preamps doesn't populate in a track when selecting a PRE input path. Nothing about my config, either physical or software has changed. I swapped out the USB/Midi interface, no difference. PT Ultimate upgrades appear to be the only variable.
AVID indicates that this box is no longer supported, but so are a number of other peripherals that still work and require a heftier set of specs than MIDI. I'd like to believe that AVID wouldn't deliberately tank the MIDI integration with the older PREs...but given the radio silence from them on my trouble ticket, I'm wondering.
Anyone else seeing this?
Old 09-10-2018, 07:05 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Digi PRE (Blue) no longer talking to ProTools
Not fair.
Avid please assign support updating midi changes. Or publish the How To's of it.
Anyway. Try a backup then advance to MacOs 10.13.6 since your already in 13.
Trash the usual plus audio/midi prefs
New session with new default I/O. Re-setup the MIDI Peripherals n such.
Old 09-10-2018, 10:20 PM
laki laki is offline
Sorry if this seems like a silly question. Just trying to help...
In the I/O setup, on the Mic Preamps Tab, have you selected which 8 inputs the Pre will show up on?
Old 09-11-2018, 09:08 AM
Yes, absolutely. But thanks because it's often those little things, right?
Old 09-11-2018, 09:09 AM
Originally Posted by DetroitT View Post
Not fair.
All kinds of red flags on AVID site about no compatibility beyond 10.13.3. I'll try the rest of what you suggest and let you know. Thanks.
Old 09-12-2018, 08:02 AM
feliponk's Avatar
feliponk feliponk is offline
That shouldn't be happening. The PRE MIDI protocol is used by other vendors, and still works, like in my HAPI for example, and for shure it should be working on Avid's own hardware.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Auto Low Latency On/Off ("Blue Mode") setting no longer imports... O.G. Killa Pro Tools 12 0 10-28-2016 05:02 PM
Sync-blue and midi-blue with protools 11? John Becool Pro Tools 11 4 09-11-2013 10:28 AM
How Much Longer til They Fix Digi 003? J-Xile Windows 10 03-09-2011 02:29 PM
Axiom 25 and Digidesign Strike. No longer talking/working with each other. Schizm Virtual Instruments 0 10-27-2009 08:41 PM
Digi 002 not talking Fitzy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2007 10:24 PM
