More issues with Plugin Presets
HI everyone. My question regarding presets was never answered. With Digirack's Compressor/Limiter II, I was able to use presets to allow for general compression/limiting, then fine tune from there. However, since upgrading to LE 7.4, and subsequently, Compressor/Limiter 3, presets no longer exits. Am I out of luck, or am I able to find these presets somewhere in a system drive?
~Kevin iMac 2GHz Intel Core Duo OSX 10.5.2 2 GB DDR2 SDRAM Mbox 2 LE 7.4 |
Re: More issues with Plugin Presets
Well the DynamicsIII is in the plugins folder and it does have presets already set for it. Inside the "UN-used Plugins" Folder is where you find the Dynamics II and EQ II plugins. Apparently those teo do not work well with PT7.4.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Yeah, I have it in the plugins folder too, but still, no presets when I use it as a plug in? Is it a Leopard compatibility issue?
~Kevin |
it shouldn't be dude. I am running Leopard 10.5.1 right now with 7.4CS3 and it's fine.
It's weird, I don't know what the deal is. Does it have to do with an update of some kind? Did I not install Pro Tools properly?
At least it's good to know that they do exist, and I just need to get a hold of them. And I'll for sure be set when Leopard gets supported! ~Kevin |
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
plugin presets? | fasttraxx | Tips & Tricks | 14 | 07-01-2007 11:09 PM |
plugin presets | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-04-2004 05:50 AM |
Plugin Presets | bruvey | General Discussion | 0 | 10-03-2002 05:09 PM |
why cant I see the plugin presets | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 2 | 10-01-2001 04:55 AM |
