Latency issues
I'm on a HDX rig. I occasionally get latency issues and I'm trying to get this figured out once and for all. When I'm doing a mix I usually put the hardware buffer size up to 1024. I just tried doing that and am getting vocals that are not playing back in time with the song. If I put it back to say 256 the delay goes away for the most part but it doesn't feel like it as in the pocket as when it is at 128. At that level I get CPU errors. I'm running Aux subgroups out to a summing mixer and then returning into Pro Tools to a master bus. That track then goes to an audio track that I keep in input mode and record. When I'm ready to bounce a mix I hit record and let it run in real time. Is there something inherently wrong with this setup in terms of the way PT's handles delay compensation? Would love to get rid of this issue!
Re: Latency issues
Curious why you are using Aux channels rather than straight hardware sends.
Sent from my iPhone using Tapatalk Pro |
Re: Latency issues
Let me clarify, I'm using Aux's as subgroups and each one of those goes to a separate Stereo Master. So for example, drums sub goes to a master that outputs to 3-4, bass sub goes to a master that outputs to 5-6, etc. All of these are going to my summing box inputs.
Re: Latency issues
You REALLY want to avoid running live recording tracks through any kind of bussing while tracking - it adds a bunch of delay that is not needed.
Re: Latency issues
After more experimentation, this seems to be related to plugin induced delay. Is there a specific threshold of plugin delay that is just too much for delay compensation to handle? |
using VE Pro latency issues | Anibal | Pro Tools 10 | 0 | 01-13-2014 04:28 PM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Latency Issues, Please Help!!! | daveseviltwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2010 07:01 PM |
latency Issues | Stratdw | Pro Tools M-Powered (Win) | 3 | 12-19-2009 01:27 PM |
Latency issues with 001? | Bubblegum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-17-2003 06:50 AM |
