Command+Shift+0 on MacBook Pro not toggling between Edit & Mix Windows
Hi!
Can anyone confirm that the Mix/Edit window toggle shortcut - in my case on a MacBook Pro Command+Shift+0 (zero) - does not work? Does the shortcut Command+= work on the "big" keyboards?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: PT 11.1 Mix/Edit window toggle not working
Just Command + works for me. Thats the shortcut I've always used.
Command + what?
On Laptop keyboards there is no = , only as shift+0... ...and it worked in 11.0.x and still does in 10.3.8, but not in 11.1...
"command" and "+"
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
No, Command and + does zoom in horizontally, again, on a MacBook Pro keyboard.
When pressing Command+Shift+0 the Window menu does turn blue, which indicates that a shortcut of its list has been pressed. So the shortcut is not wrong. Because when i activate the window menu (so that i see the menu list) and press Command+Shift+0 the shortcut works!
Confirmed - same issue here
On WIN some of the short cuts only works when i have set my keyboard to US...maybe something like this on Mac also??
Regards www.h-musikk.no/english.html Norway ASUS X99-E, Intel Core i7-6850K, Noctua NH-U9S, Corsair Vengeance LPX DDR4 2133MHz 16GB, Samsung 960 EVO 250GB M.2 PCIe SSD (System), Samsung 850 EVO 500GB 2.5" SSD (Data), Samsung 850 EVO 1TB 2.5" SSD (Sample), WD Desktop Black 1TB 3.5" (Audio), Gigabyte GeForce GTX 1060, Corsair RM750x 750W, Samsung 34" LED Curved, Windows 10 Pro 64-bit, Lynx AES16e, Aurora 16, Cakewalk by BandLab, Pro Tools 2021 |
Thanks! I hope it will be fixed soon. No. 1 shortcut on laptops for me!
command plus = works on my mb pro
Hmmm, ok. And you do "Command" and "=" like i do it? ("=" is "shift" and "zero")
Toggling plugin maps on d-command ? | yellowshaman | ICON & C|24 | 25 | 12-21-2012 12:48 PM |
SHIFT COMMAND WHY | germ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-12-2003 05:20 PM |
Nudge vs Shift Command | lcpellerin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-04-2001 01:53 PM |
Can't "shift-command-B" sometimes... | dans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-22-2000 11:38 AM |
Losing [command][shift]B | trombino | Pro Tools TDM Systems (Mac) | 12 | 07-12-2000 06:30 PM |
