Old 05-08-2003, 05:19 PM
gavinchan gavinchan is offline
Default 9020 with 002 (on 64 and 128 Latency)
I know you are probably all sick of 9020/9029's ect... but I have done a exhaustive search and I need some help with a specific problem.
First the specs:
P4 2.4 Northwood, MSI 845PE Max MB
512MB 2700, 40GB system, 80GB Audiodata ,
Sony CD-RW 32X8X4
all running off onboard IDE
ASUS MX440 64MB AGP
Swannsmart Firewire
XP Home, (massively tweaked to barebones)
The Problem:
Whenever I play a track at lower latencies... (64,128,256) About 1 bar before the audio actually starts it gives me a 9020/90xx. If I press OK and play again, it continues and the rest of the track plays just fine / no errors. It seems to be some kind of HDD thing but I'm not sure... I can almost garrantee it, on different sessions too. These sessions arent particularly intensive either, maybe 2 midi tracks and 3 audio tracks.
What I have tried:
Disconnecting the CD-ROM
Checking DMA is enabled.
Disabling all startup progs and unnessesary services
Installing Intel Applications Accelerator
Using the Seagate HDD Utility to slow down Audio drive to UDMA 66 / 33
The only thing installed is ProTools / bundled plugs.
APIC is anabled and my Firewire card is on IRQ 18, does this sound sus to anyone, should I do a fresh install with "Standard PC" enabled? [img]images/icons/confused.gif[/img]
Anywho, any comments / suggestions are welcome
Thnx! [img]images/icons/grin.gif[/img]
Old 05-09-2003, 12:27 AM
Default Re: 9020 with 002 (on 64 and 128 Latency)
(Insert noise of crickets, and person coughing in the distance here).........
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
-9020 Buffer Size error gadafly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-06-2007 09:19 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
