Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-18-2014, 02:33 PM
wgouldsby wgouldsby is offline
Default Bit rate
When I am bouncing a project to disk, what is the best bit rate? 16 or 24? I am running Protools 9.0.5 on a Mac (OS 10.8.5). Thanks in advance for your replies.
Old 04-18-2014, 02:37 PM
Default Re: Bit rate
Depends on where the project is going. I'd keep it at 24 bit until final mixdown and then if you're going to cd dither down to 16 bit at 44.1 KHz.
Jack
QAPLA!
Old 04-18-2014, 02:44 PM
Thanks for the reply. I am bouncing to disk and once it is there I am importing it into my iTunes library where I will then convert it to an AAC file. Am I on track? Thanks for the speedy reply!
Old 04-18-2014, 02:46 PM
Don't know about AAC so I can't answer to that.
Jack
QAPLA!
Old 04-18-2014, 02:47 PM
How about MP3?
Old 04-18-2014, 02:51 PM
How about MP3?
16 bit would be fine as 24 bit would be overkill
Jack
QAPLA!
Old 04-18-2014, 02:52 PM
Can you tell the difference by listening? In the AAC format, I can't tell.
Old 04-18-2014, 02:56 PM
You would need to be listening to an uncompressed format and have good ears to tell the difference.
Jack
QAPLA!
Old 04-18-2014, 03:01 PM
An uncompressed format would be a wave file, correct?
Old 04-18-2014, 09:49 PM
Yes,(or AIFF on a Mac). In any case, what bit depth is the session? If its already 16 bit, there is nothing to gain by bouncing to 24 bit. My preference is to bounce at the session sample rate/bit depth(and I ALWAYS record at 24 bit for the extra headroom). Then I open the "2 mix" in Wavelab so I can trim the head/tail, add a fade if needed, do any mastering(if the product is not going to an ME) and add dither if I am going to need 16 bit/44.1K for an audio CD. Otherwise, Wavelab is fine for creating mp3 versions from the original file format.
auto matching pull factors + frame rate + timecode rate Dingo90 Post - Surround - Video 1 10-17-2009 04:16 AM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
mp3 bit rate question 128 / 320 ? constant bit rate TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-04-2008 02:07 AM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
Bit rate & Sample Rate WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2002 12:54 AM
