Corrupted file PT 10.2 mac os x
I've downloaded the installer from AVID many times and each time I try to install it give me a corrupted file error. I'm going crazy. Any one have another way to get the file?
Re: Corrupted file PT 10.2 mac os x
First check to see if you have downloaded the complete file:
It is possible that a different application is trying to open the disk image, and some (like Pacifist) will not be able to open it, where the default Apple DiskImageMounter application will open it. You can also open/mount it using Disk Utility (in Applications/Utilities), choosing File>Open Disk Image. If none of the above works, then you should try deleting any downloads that begin with the name "Pro_Tools_10_2_Installer", including partial downloads. Then you should clear your browser cache, and try downloading again. Or try a different browser. Or last thing to try, download to a different hard drive than you normally do, to eliminate a possible partial cached download. |
Corrupted WAV file | gonzolagonda | Pro Tools TDM Systems (Mac) | 19 | 06-21-2014 10:09 AM |
Corrupted .ini file? | GTBannah | Windows | 5 | 11-18-2012 08:16 AM |
Corrupted Session file | TULL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-17-2005 09:02 AM |
HELP! Corrupted file! | GrantE | General Discussion | 0 | 04-21-2003 07:44 PM |
Help with Corrupted File in HD (Urgent) | everglass | Pro Tools TDM Systems (Mac) | 6 | 06-29-2002 06:10 AM |
