#61
Re: Pro Tools 9 Crashes When Selecting Audio Interface
Also make sure you leave at least 1 processor core free for non-realtime plugin processing. Example: In your playback engine if you have 8 processor cores, set it at 7 or less. This sounds couter-intuitive, but it has fixed a lot of people's problems with plugins causing crashes along with getting them upgraded to a tested and working plugin version for Protools 9.x
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#62
I don't think it's a "PLUG IN THANG" I just did everything suggested and when I opened an older session my Hybrid wasn't working. I checked the IO, aux buses and to see if my midi notes were muted... they weren't and I lost the bass line to the track I'm working on. So, I inserted another instrument channel, opened another Hybrid and copied the midi notes from the preceding one and it worked. I then had to copy the settings and hope to get the same sound. Also my Moogerfooger Analog Delay, Ring Modulator and Fairchild plugins are not recognized anymore. Am I missing an update for the latter plugins? does Avid even offer one?
#63
If it works with no plugs, add one plug at a time, re-boot and see if it works. PT will give you grief if an outdated plug in in the system, even if you don't load that plug in a session.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#64
Park, Thanks for your help in trouble shooting this. Yes I've checked compatibility but haven't tried to hold the "Space" key. I don't think it has anything to with my my plugins my preferences keep changing from session to session, sometimes the plugins work, sometimes they don't. Today I used a template from an earlier session and the IO didn't work I got no sound at all, when I opened the original session the sound worked as normal. I reopened the clone session and again no sound, I checked the IO settings deleted all and imported the one I made for my set up and still no sound. I would like to send you the screen shots I have but I don't know how. I forgot to mention the pop I get when I change routing in the session. |
#65
Take a look here:
http://avid.custkb.com/avid/app/self...p?DocId=356111 It is the Tech Support folder you can download. Check this info about plugs: http://avid.custkb.com/avid/app/self...p?DocId=353941 Upgrade info: http://avid.custkb.com/avid/app/self...p?DocId=353265 General troubleshooting: http://duc.avid.com/showthread.php?t=54888 Hope it helps.
#66
Did you try this?
started about 3:00 into the video. |
Pro Tools crashes on quit, doesn't work with Tascam Interface | epignosis567 | Getting Started | 100 | 04-08-2013 07:05 AM |
Pro Tools 9.06 Crashes when Selecting Faderport | HDM | Windows | 0 | 10-11-2012 06:20 AM |
Crashes when selecting 96khz | jackgnic | Pro Tools M-Powered (Mac) | 1 | 08-06-2008 02:56 PM |
HELP - Protools LE 7.3 crashes when selecting MBOX 2 Output | revola | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-17-2008 09:16 PM |
Selecting Midi Patch Crashes!! Why? | chrissimian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-23-2005 06:56 PM |
