Re: Pro Tools 9 Crashes When Selecting Audio Interface
Hate to be the guy who bumps threads, but has anyone else been experiencing this and/or found a workaround? This makes PT 9.0 unusable!
I had to boot OSX in 32 bit mode and reinstall my 32 bit Apogee drivers. Try holding down the 'n' key while booting PT. This should allow you to choose a audio device without crashing.
8 Core Harpertown 3.0 Apogee Symphony 64 / Rossetta 800 |
The Pro Tools 9 Technical FAQ has some possible solutions.
My Mac defaults to 32-bit mode and all my audio devices have the latest drivers installed and work fine in other audio software (Cubase, Logic, Live). |
(To be clear, I uninstalled Pro Tools M-Powered 8.0.4 using the provided uninstaller app and installed Pro Tools 9 using the full 4.7GB installer.) |
#16
Did you try holding the n key while it boots as suggested?
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#17
I'm having similar issues and i fell ripped off by avid, i bought a presonus firestudio 26 and i bought pro tools 9 and it IMPOSSIBLE to run directly with the presonus, i'm only availaible to run it wth asio4all, and the farthest that i can get is to initialize pro tools, open the session but then there is no playback, it just 'freezes' there. Im so frustated right now :@
#18
(For the record, if I hold n while Pro Tools launches and get the Playback Engine dialog, selecting an audio interface from the menu crashes Pro Tools just the same.) |
#19
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#20
Also, PT always defaults to my ProFire Lightbridge interface which is 34 ins / 36 outs and works just fine - I can play and record audio with no problems. |
Pro Tools crashes on quit, doesn't work with Tascam Interface | epignosis567 | Getting Started | 100 | 04-08-2013 07:05 AM |
Pro Tools 9.06 Crashes when Selecting Faderport | HDM | Windows | 0 | 10-11-2012 06:20 AM |
Crashes when selecting 96khz | jackgnic | Pro Tools M-Powered (Mac) | 1 | 08-06-2008 02:56 PM |
HELP - Protools LE 7.3 crashes when selecting MBOX 2 Output | revola | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-17-2008 09:16 PM |
Selecting Midi Patch Crashes!! Why? | chrissimian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-23-2005 06:56 PM |
