Old 02-20-2010, 06:21 PM
tejaso tejaso is offline
Default More than one VST doesn't work?
I'm trying to use my Fantom G as a scratchpad sequencer to control virtual instruments on Pro Tools and have PT slaved to the Fantom. I'm having the problem that I can't seem to record/playback more than one instrument. Whatever instrument I have selected, all of the midi channels that I transmit (or try to transmit to different instruments) goes to that one selected instrument. I have the midi setup to only send/receive on the VST track to the midi channel I want to use but that seems to make no difference. I must have something set up wrong but I'm not sure what that is. Could someone explain how to control multiple instruments on PT (like a multi-channel midi instrument source)?
Old 02-20-2010, 06:29 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: More than one VST doesn't work?
Just arm the tracks u want...(hold shift & record)
& its not VST, but VI
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 02-22-2010, 06:00 AM
I can arm them and record. It's just routing all midi data previously recorded to that one armed track.
Old 02-22-2010, 07:22 AM
Are u not just wanting to stack sounds? thatz what ur basically wanting to do correct?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 02-22-2010, 02:58 PM
Stack sounds in the sense that I want to be able to treat PT as a slave device initially while I scratch out the main idea on my Fantom, using its sequencer to control multiple VI's on multiple midi channels.
Once I'm ready to edit, mix, record, then import the midi data into the correct channels/VI tracks and use PT as the master device controlling the Fantom. The latter part works just fine. Mainly I want to do this because the Fantom sequencer is a little easier/quicker to use for sketching the main idea.
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
The plugs that WORK and DON'T WORK on 7.0 The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-10-2006 10:12 PM
New Mic won't work DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2002 09:06 AM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
