All MIDI is inactive when opening a session, until i open OMS Studio Setup and......
All MIDI is inactive when opening a session, until i open OMS Studio Setup and do a "test studio".. Then I go back to protools 5.1 and all is well. When I first open up a session, and i rec enable a midi track, PT recieves NO midi input from my controller and also doesnt send any pre recorded midi out. I dont see any midi meters in PT when i hit keys or move the mod wheel or whatever.. Total MIDI silence..
If I keep PT open, then go to OMS and test studio to "wake up " the midi, on switching back to PT, everything is back to normal... Its really a drag having to do this everytime.. Anyone have any ideas about this? PT 5.1 Mix, G4 466, OS 9.1, OMS 2.3.8 with serial DMA option turned OFF, Studio 4 interface... umm i guess that is all that might be relevant... please help digi.. thanks MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Re: All MIDI is inactive when opening a session, until i open OMS Studio Setup and......
Hey Mt.
I've seen this as well, not all the time though. When I get my rig set up again I'll try to get a more scientific explanation. - Jan |
go into OMS Setup. In the Edit menu open the 'OMS MIDI Setup' option. make sure 'Run MIDI in background' is checked!!!!
Problem solved. Don |
yep, you da man Don...
I used to always have that checked, but since I got my new G4, i just installed OMS and used the OMS setup from my old computer, but never checked that pref... thanks a bunch, you rock MT
Pro tools 10.1 I open session tracks wont play says output map is currently inactive | shamanrock | Windows | 16 | 01-23-2013 06:22 PM |
I/O default setup, DigiBase catalog, opening session | tgtl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-03-2008 04:20 AM |
Making Inserts Inactive on Session opening | Sebopath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-09-2006 10:26 AM |
Unable to open Midi Studio Setup | yvan | Pro Tools TDM Systems (Mac) | 8 | 08-25-2005 03:55 PM |
I can't open the MIDI studio setup | moiblest3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-24-2005 10:00 AM |
