9020 with 002 (on 64 and 128 Latency)
I know you are probably all sick of 9020/9029's ect... but I have done a exhaustive search and I need some help with a specific problem.
First the specs: P4 2.4 Northwood, MSI 845PE Max MB 512MB 2700, 40GB system, 80GB Audiodata , Sony CD-RW 32X8X4 all running off onboard IDE ASUS MX440 64MB AGP Swannsmart Firewire XP Home, (massively tweaked to barebones) The Problem: Whenever I play a track at lower latencies... (64,128,256) About 1 bar before the audio actually starts it gives me a 9020/90xx. If I press OK and play again, it continues and the rest of the track plays just fine / no errors. It seems to be some kind of HDD thing but I'm not sure... I can almost garrantee it, on different sessions too. These sessions arent particularly intensive either, maybe 2 midi tracks and 3 audio tracks. What I have tried: Disconnecting the CD-ROM Checking DMA is enabled. Disabling all startup progs and unnessesary services Installing Intel Applications Accelerator Using the Seagate HDD Utility to slow down Audio drive to UDMA 66 / 33 The only thing installed is ProTools / bundled plugs. APIC is anabled and my Firewire card is on IRQ 18, does this sound sus to anyone, should I do a fresh install with "Standard PC" enabled? [img]images/icons/confused.gif[/img] Anywho, any comments / suggestions are welcome Thnx! [img]images/icons/grin.gif[/img] |
Re: 9020 with 002 (on 64 and 128 Latency)
(Insert noise of crickets, and person coughing in the distance here).........
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
-9020 Buffer Size error | gadafly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2007 09:19 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
