Old 07-25-2013, 03:49 PM
A1rstudios A1rstudios is offline
Default Clicks and pops when trying to record.
Hi I have problems with clicks intermittent when i set a track to Rec enable, I am using an 888/24 with an adat bridge/24. This only happens when i enable the adat digital tracks. The adat light pipe is connected to the first 8 tracks of an Otari Radar 1. I have tried changing the interface cables connecting both 888 & adat to the y cable from the Mix core Card (which resulted in loss of dsp for extra Reverb One) and also the original config, 888 connected to Y cable A be left unconnected and Adat connected to DSP Farm(Correct Rev). At first i thought it was a Clock problem so i purchased a cable to run from the Otari Radar master to Adat bridge but just got digital noise when Rec enable. I alos tried conecting adat bridge to 888 with the clock cable but it has made no difference i am still getting the clicks.
I have had this setup for a few years but never used it with the adat bridge diital inputs
Any help would be great Thanks
Old 07-25-2013, 11:33 PM
JFreak JFreak is online now
Default Re: Clicks and pops when trying to record.
Isn't the RADAR-I only 16bit device? I might remember this wrong, though, but if it is and you have a 24 bit session you might have your problem right there.
But let us assume I remember this wrong and it indeed is a 24 bit device. Anyway, you have to have all digital gear connected, not just two.
- First, sync the black boxes by feeding a clock cable from the master unit to the slave. Do not loop it back, though.
- Then connect ADAT both ways, input and output, so the synced clock goes to your ADAT device.
- Last, set the ADAT device to sync to your clock signal.
*OR* grab a used master clock and feed that clock to all your boxes.
Once you have all digital boxes in sync, the pops will go away.
Old 07-26-2013, 02:10 PM
Hi Yes you are right Radar 1 is 16Bit so i changed the session to 16Bit but still got the Clicks, But following your next advice cured the problem, Both Digi black box's linked with clock cable My problem was the Radar was sync'd to wordclock not Adat once changed all was fixed.
I also took the Y cable off the system and connected the 888/24 to the mix core and the Adat bridge to the DSP farm and getting extra Reverb One. Am i right in saying that the Y cable in Place is lowering the DSP even if only A is used.
Anyway Thanks for your help Great stuff
Martin
Old 07-27-2013, 10:12 AM
No. The purpose of a Y-cable is to feed 16 i/o to a MIX card. A MIX card can handle 16 i/o but not all cables can feed that much. So it's just a workaround.
The cable used with 1622 is a 16 channel one, but the other ones can only carry 8 channels. So, combine two 8 channel cables and your MIX card is happy to see all 16 i/o that it can handle.
There is no other magic.
Mbox 2 w/ Pro Tools 8, clicks and pops during record and playback ssiimm85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-27-2010 05:11 PM
Clicks and Pops in destructive record mode DAPG Post - Surround - Video 12 08-09-2010 05:49 PM
Clicks and Pops During Record But Only Heard on Playback jrtme Pro Tools TDM Systems (Mac) 9 12-09-2009 08:17 AM
Clicks/Pops on record at 96K Snitz Pro Tools TDM Systems (Mac) 6 12-04-2006 04:06 AM
HELP! - Pops and clicks on record-enabled tracks Spitshine-Drums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-18-2004 10:20 PM
