Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-28-2020, 10:12 PM
Munnin Munnin is offline
Default What happened to the tabs? [SOLVED]
Am I imagining things or were tabs done away with? I actually preferred them to multiple windows, even if I used the shortcuts. It at least kept everything tidy.
Old 11-29-2020, 08:11 AM
Default Re: What happened to the tabs?
I've been using Pro Tools for 18 years and don't recall any "tabs"
Old 11-29-2020, 08:28 AM
rampartthemovie rampartthemovie is offline
im pretty sure tabs never existed, maybe you are confusing it with a plugin you were using that had tabs?
Old 03-11-2021, 01:28 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
FOUND IT!! I was just setting up a system in one of our new edit bays and everything ProTools opened had TABS in the window... one for the editor and one for the mixer.
It's a Mac setting in, believe or not, DOCK. There's a pull down menu next to "Prefer tabs when opening documents:" with the selections Always, In Full Screen Only, or Manually.
To the OP, Change it to Manually and they'll go away. Change to Always and the obvious happens and your tabs are back.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
What happened to my plugins ? [SOLVED] Terry Wetzel Pro Tools 9 3 12-31-2015 11:10 AM
Import I/O-Setup for all tabs? Meads Pro Tools 11 6 08-08-2013 12:49 AM
Guitar Tabs Becharax Eleven Rack 2 06-10-2013 06:21 AM
manually setting warp tabs/ deleteing multiple arp tabs glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-22-2010 01:31 PM
Help With Tabs & Timebase Rulers... rmccam Pro Tools TDM Systems (Mac) 2 06-18-2004 02:19 PM
