Old 02-19-2013, 12:04 AM
aasteveo aasteveo is offline
Default Surround Panner 'select track' shortcut?
I've got this Surround Panner:
http://www.avid.com/US/products/Surr...-for-Pro-Tools
Running PT10 on OSX10.7.5 using a C|24 control surface.
In the manual it says "The Next Track switch moves panner focus to the track below (Edit window) or on the right (Mix window)."
But I haven't found an easier way to select my track. Is there a key command I can use? Can I make it follow my main edit window track selection? It seems to operate independent of everything else. Is there a button on the C|24 that can help me?
I found out that holding Option and pressing the Next Track button will take me to the last track in the session, or first track, which is nice, but it's still very limiting and time-consuming to operate this way.
Sorry for my ignorance, I'm new to this product, but the manual doesn't say anything about a shortcut key command, or how to make it follow my main track selection. Maybe I'm missing something, but is pressing that little 'next track' button the only way to select which track I'm using?
Shortcut to Select Next/Previous Track headsup macOS 8 02-21-2012 01:23 PM
Magic Track Pad as Surround Panner? FluffyPost Post - Surround - Video 30 01-25-2012 12:25 PM
8.01 Surround Track File select Bug ? Feature ? TommyT Pro Tools TDM Systems (Mac) 0 10-06-2009 04:46 PM
surround panner Peter Groom Post - Surround - Video 3 05-28-2007 07:53 AM
Surround Panner for LE MikeTrahearn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-23-2006 07:40 AM
