Spotting audio - Work Flow
I am creating lots of stems in PT12, simple drag and drop from the Finder at the moment . when using timestamped files I simply drop one file at a time with spot selected and hit Org TC arrow in the dialog .. but it is very slow.
is there a quicker way ? the other option is exporting my Stems for LPX 10.2.1 in a single bounce offline which is very quick, but the files are then not TimeStamped. is there a way to drag a number of Files onto the timeline and snap them to the current play head ? as the main mix file I bounce in real time in LPX and that is TimeStamped.. any help with be welcome. |
Re: Spotting audio - Work Flow
timeline insertion at the desired point clip list : select all stems, Ctrl-drag to the tracks (just drag over the tracks somewhere, release mouse, stems will be placed with their start to the timeline insertion automatically). My offline bounces are timestamped. Can be spotted after manual import or are placed correctly when using "import after bounce".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
This was a really help "Control" thats the key I was looking for , you can also do it from the finder but you have to press if after the files or on the PT GUI..
thanks! so if you have time stamped files (which do not all start in the same place do you select Spot then drop each file have the the "Orig time stamp " up arrow for each file ? is seem to take for even and the dialog only appears on the main monitor which slow for me |
My pleasure.
elastic audio - corrective work flow | joeymusicguy | Tips & Tricks | 1 | 04-23-2010 10:03 AM |
Elastic Audio work flow question | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-29-2009 06:57 AM |
work flow problems | volanto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 07-25-2009 06:30 PM |
Work flow in Pro Tools | bedigi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-27-2008 03:33 AM |
Work .. erm .. flow ? | Bobbers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-15-2007 03:41 AM |
