Grid Timing is shifted - don't know how to fix
Hi
In my current edit window view, I have a heavy blue gridline lined up with each bar. The zoom is set so that each bar is sequential , 1,2,3,4, etc. Each bar is then sub-divided into 16 sub-gridlines. All of this is fine. My problem is that when going from bars 70 to 73, the numbers and gridlines for 71 and 72 do not show up. And the spacing between 70 and 73 is compressed, it is not equal to the amount of space(time) that would be correct if the 71, and 72 bars were there. I am assuming that somehow there is a tempo change inserted, but I don't know how to fix this. Any advice would be appreciated. I have Protools 8 running on imac snow leopard with a digi oo3 |
Re: Grid Timing is shifted - don't know how to fix
It's on the menu bar under the HELP section. Good luck.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Thanks for the help.
You give me a key clue, which was to look at metering. I displayed the Meter toolbar, and found a little yellow meter marker in the corrupted area. I was able to move it out of the way, but I have not been able to delete it. Do you know how to delete a meter marker? |
left-click and hold on the marker and drag it up.. Or, left-click and drag across one or more markers and highlight them, then just hit delete.
Hi
I couldn't get the drag up thing to work, but when I dragged across it and deleted it worked great. Thanks again for your help!! |
My grid somehow got shifted last night...please help! | SlickEnz | Windows | 2 | 08-05-2011 05:02 PM |
Artist want's odd timing, but we want it to stay on the grid. | ericsvizeny | Pro Tools 9 | 5 | 07-17-2011 11:24 PM |
Help! MIDI Notes Shifted! | Nicky P | MIDI | 10 | 04-12-2011 04:34 PM |
2 Tfts 90° shifted - anyone done that? | Meads | General Discussion | 11 | 01-05-2011 08:32 PM |
Tempo/Beat Map Grid to fix drum timing? | El Guapo | Tips & Tricks | 8 | 11-03-1999 09:51 AM |
