192 i/o 16 analog and in and out?
anyone know if you can remove the D/D card and have 16 analog in and out by adding a A/D and D/A
Cheers Andy |
Re: 192 i/o 16 analog and in and out?
No, that will not work----and in fact if you try to remove it you could potentially damage it. If that happens, it will NOT be fixed under warranty.
Ok cheers
Andy |
Hi, Its one or the other! 16 in 8 out or 8 in 16 out you can use the adat or AES digital to get another 8 i/o at the same time. good for 8 pre's going in but not so good if you need another 8 hi-quality inputs/outputs, but there are quite a few dig converters to do this. Chris
Well come on Chris---that latency must be way up there, adjust it down and you'll be right in time as everyone else on the response!
I have a 192 with the extra A/D card... can I also have 8 ADAT inputs as well for a total of 24 simultaneous inputs?
Ray Trujillo Freelance Audio Engineer |
Unfortunetly you can't. In the IO setup window there is only 16 "spots" from left to right for each 192. So even though you can use all 24 ins, you can't use them all simultaneously, you have to select 16 of them corresponding to the 16 columns underneath the 192 IO in the IO setup window.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
But wouldn't that be a great new product for Avid to come out with! It could be the first new "Avid" branded interface for PTHD. If they put a new power supply in the 192, they could make a 16 AD/16 DA interface to compete with the Aurora and Apogee. This would also give us the ability to have 16 hardware inserts in one box. Maybe if enough of us here speak up and let them know that's something we want, they might do it!!! Anyway, count this as my vote for a 16AD/16DA AVID 192IO!
thanks... I'm gonna call you Buzz Killa.
just get a external AD/ and DA for the digital IO card
that will give you 16 analog
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
Digidesign with analog preamps vs analog console?? | Lukassus | Pro Tools TDM Systems (Mac) | 2 | 11-20-2005 01:13 PM |
Interfacing 888 analog output with analog console | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 09-12-2003 01:26 PM |
Getting that perfect Analog sound without analog gear | remote | Pro Tools TDM Systems (Mac) | 7 | 03-28-2003 12:25 AM |
analog to digital to analog | major_thom | Tips & Tricks | 5 | 09-19-2001 04:02 AM |
