HDX ASIO Problem...
I have a big problem with my HDX Hardware and ASIO...
On every other Daw using Asio, my Asio Buffer is fixed at 1024... It doesn´t matter if i change it in the Asio Control Panel... 64 128 or 256... The Driver won´t change. It stays at 1024... in Reason 10, Samplitude Pro X3... So i cannot use this software for softsynths and more... Is my HDX Card the Problem... |
Re: HDX ASIO Problem...
Using HDN/HDX hardware has been problematic for years with other software.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
I have run my HD Native hardware with other DAWs on a Mac for years flawlessly. Windows or Mac?
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Ah ha, so I have earned my nickname of Captain Obvious today....LOL
If that is the case, would it be similar to other interfaces with Windows and not being able to switch sample rates because the HDX card is being used as the default Windows interface??
Hehe! Yes, Avid hardware gets really unhappy when Windows takes it over. Best to use the on-board sound card for other programs. In my case(HDN on Windows) I take the optical SPDIF output off the motherboard and that goes to my Presonus central Station. You might be able to feed that SPDIF(optical or RCA, depending on the motherboard) to an input on your interface to get sound from the other programs(but it might also require Pro Tools to be open in the background for routing)
Make sure that the software / instruments you are using are set to "Run as Administrator". Otherwise, they cannot assume full control over the Avid Hardware.
Martin Trum |
Manichouse... you are brilliant... Thank you so much... After starting Samplitude and Reason with right click and "run as admin", the avid asio driver works and i can change the buffer... Great... thank you, problem solved...
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
Problem with ASIO and 002 Rack. | spinweb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2010 08:01 AM |
ASIO problem.. i think.. | 2ooster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-01-2009 06:15 PM |
ASIO Problem | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-10-2004 03:06 PM |
002 ASIO Driver Problem | shipwrecked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2004 05:36 PM |
