Old 10-29-2014, 06:39 AM
keenonrush keenonrush is offline
Default upgrade to Yosemite now old sessions will not open
So I updated ios to Yosimite and now when I try to open a session, really all the sessions, that i created before the update Pro tools simply doestn't open the session. It brings up the uploading tracks screen and just the click track trying to be opened. I let it sit there for 20 minutes and still no progress. Any suggestions on what to do?
KR
Old 10-29-2014, 06:42 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: upgrade to Yosemite now old sessions will not open
KR
Can you open a new blank session ok?
If you can open a new session then once opened try using import session data and try just one track at a time?
Are all your plugins up to date?
Whats your system specs? and pro tools versions used?
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-29-2014, 04:57 PM
mattrixx mattrixx is online now
Do any of these session that don't open have either NI Guitar Rig or Maschine in them?
If so, remove the AVID Core audio plugin from:
MacHD > Library > Audio > Plug-Ins > HAL > "in here"
.....and re-boot
Regards,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacPro 6,1 6core 32GB / LogicProX / IzotopeRX8+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFXII / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-29-2014, 09:43 PM
TimNielsen TimNielsen is offline
So since ProTools isn't even remotely supported in Yosemite yet, and there have been various issues here on the DUC, why the hell would you update? Hopefully you backed up your old OS and can restore it.
Old 10-29-2014, 09:45 PM
What are some of the other issues? It's working fantastically here (I have a disk clone to fall back on if needed, however, I have various other reasons to have upgraded).
Matt McKenzie-Smith
mattrixx.net
Old 10-30-2014, 01:03 AM
beckycordova@yahoo.com beckycordova@yahoo.com is offline
I have an LE8 m box and bought a Mac Mini OS 10.9 Maverick...can you tell me what I have to do to get My pro tools to be compatible with my m box?
Old 10-30-2014, 01:12 AM
JFreak's Avatar
JFreak JFreak is online now
KR
I had no such problems. Did you upgrade old system to Yosemite, or did you do as you should and erase the system drive first?
Here are the instructions for creating the installer boot stick.
Welcome to the forum :)
Janne
Old 10-30-2014, 01:16 AM
JFreak's Avatar
PT LE8 requires Snow Leopard (10.6.8) so if you mean you bought new Mac Mini that comes with Mavericks, then no, your system is not compatible. You need to upgrade PT LE8 to PT11 but wait until November.
Here is the compatibility information regarding PT LE in case you want to be looking for old compatible computer for it instead of upgrading software.
Janne
Old 10-30-2014, 05:10 AM
perh perh is offline
Guitar Rig 5 and Machine has problems with their respective driver software. If you can work without you can remove the driver from:
./Library/Application Support/Native Instruments/Hardware/NIHardwareAgent
- and you should be fine, until an upgrade is provided by NI.
Apart from broken menu's Pro Tools 10 is working fine here. Not my main DAW anymore, but did some fixing on a mix yesterday and no problems at all.
Still think that Avid should have some respect to customers complaing on nearly a daily basis for more that a year, and either fix these very minor but annoying problems or at least come out of the bush and tell why they won't do it. "Fight like a man" - as they say.
Old 11-23-2014, 03:54 PM
dtruitt dtruitt is offline
Perth - that was awesome! I would never have figured that out! And I can certainly work without Guitar Rig 5. Thanks bunches!
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." median Pro Tools 10 5 10-01-2013 12:14 PM
8.04 will not open old sessions on xp latiffee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-09-2010 03:17 PM
sessions always open with mix window track list open jaglance Pro Tools TDM Systems (Mac) 2 08-03-2009 07:03 PM
Can you open V8 sessions in 7.4? dbjp Pro Tools TDM Systems (Mac) 3 04-10-2009 09:47 PM
PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions! chanlon25 Post - Surround - Video 4 03-03-2009 11:11 AM
