mixer for mbox
anyone know a good mixer using with the mbox with good sound quality?Not too cheap and not to expensive,who used it like this?
Regards from belgium.(you know justin hennin?) |
Re: mixer for mbox
How many other sound sources are you planning on mixing together? That will determine how many channels of mixer you will need. In general the Mackie mixers are great bang for the buck, and they make a small 12 channel mixer that works will if you don't have a lot of outboard synths or other gear to mix together with your mbox outputs.
Re: mixer for mbox
Re: mixer for mbox
As Slim said, the Mackies are nice and small. They make many models with different number of inputs.
Sometimes I use a Soundcraft Spirit Folio with my MBox. It's very small, four mic inputs with phantom power, two stereo inputs that can even be switched for turntables.
www.barnabas.com Barnabas MultiMedia |
Re: mixer for mbox
Which way do you rout a mixer to your MBox and how can I use outboard gear, ie. compressor, vocoder, etc. Should I go into the Mixer aux or into the Mbox insert? Ed
www.myspace.com/soulsainc |
Re: mixer for mbox
The M-box insert is for inserting dynamics or ouboard eq for tracking only. You cannot insert hardware dynamics using the M-box, it only has 2 i/o, except if you bounce a mono file out one, through the hardware unit and back in 2. Plugins are your only option.
Re: mixer for mbox
Why not route your signal to a mixer and effect it with your outboard gear and route it back to your MBox.
Only thing is you will have to set the track being recorded to an output other than Audio 1 and 2 otherwise you'll experience feedback. It's a wee bit tricky but it can be done, and you can monitor the track on the mixer. I've used this method before using an AMIII card and a Mackie 1202 mixer. You could either use the inserts or the Aux Send and Return. If you use the inserts you will need Y cables also known as "Insert Cables" one TRS to 2 mono 1/4" The 2 mono ends act as a send and return to the insert per channel of your effects device. If you are unsure about this method consult your local music store and ask about insert cables and what they are commonly used for.
FREE! Just send $10 |
Mbox Out>Outboard Mixer(Tascam m-208)>Mbox in??? | bblaze11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-11-2010 09:01 PM |
Mbox 2 Pro w/ mixer? | screamkingart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-22-2007 02:08 AM |
If you were me.. Mixer with Mbox? | tec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 02-18-2007 12:28 PM |
mixer and an MBOX | defretman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-17-2003 10:19 PM |
Mixer w/mbox | borednbuzzed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-29-2003 08:56 AM |
