Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 03-09-2020, 05:31 PM
tomaspal tomaspal is offline
Default S6 Surround Panning
Novice question about the S6 here. Is it possible to do surround panning from the base M40? Granted our systems have been out of support for a couple years, so we're not on the latest/greatest, but I can't for the life of me figure out how to either pan a surround track or a surround send via the S6. I had always assumed this was a native feature, but do you need the Joystick Module to pan surround from the board?
Old 03-09-2020, 06:41 PM
EddieJones's Avatar
Default Re: S6 Surround Panning
Attention a track and select the pan function block on the Master Module. If the graph doesn't pop up either change the pref to do that or drag the pan block down.
Sent from my HMA-L29 using Tapatalk
Old 03-09-2020, 06:48 PM
creativecontrol's Avatar
Additionally, here's a bit more detail on the Home page and performing an Attention on a channel to access the PAN function from the function scroller. The panner will adapt the view based on the width of the assigned output or bus path.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 03-10-2020, 11:43 AM
Perfect. Thanks, guys!
is there a way to pan a surround send (say from a mono track)? I can't seem to figure that one out.
Old 03-11-2020, 04:29 AM
This is not currently possible. Any Attentioned track populates the Master Module pan function with the primary path assigned to the track output.
Jeff
Jeff Komar
Surround-Panning domilik Avid S1, S3, Dock and Control 3 05-21-2016 01:00 PM
Surround panning of surround tracks mik Post - Surround - Video 10 12-16-2010 09:08 PM
surround panning kalos Post - Surround - Video 9 05-30-2008 06:17 PM
7.2c1 Surround Panning wierdness anyone ? Stjernholm Post - Surround - Video 27 12-09-2007 02:04 AM
Surround Panning Question gerax Post - Surround - Video 9 01-09-2007 10:52 AM
