Old 03-04-2012, 01:27 AM
New Perspective! New Perspective! is offline
Default Boss DR-880 (Drum Machine) and Pro Tools
I'm trying to use my DR-880 drum machine with Pro Tools MP9 using my M-Audio Fast Track C600.
The audio part is fine, I can hear & record what comes from the drum machine as "audio". Nevertheless I am having trouble with the midi part.
I'd like to play the drums I wrote on Pro Tools using the sounds of and through my Drum Machine as a Midi part, but I can't get the midi work at all...neitheir in the Pro Tools -> Drum Machine way nor in the Drum Machine -> Pro Tools one...I really feel disconcerted
I'm wondering if this drum machine isn't compatible with Pro Tools ? Don't think so cause midi is midi but I've been struggling with it for the last 2 days and can't find a solution...does anyone have an idea ???
Please heeeeeelp !!
Old 03-05-2012, 05:15 AM
GregV GregV is offline
Default Re: Boss DR-880 (Drum Machine) and Pro Tools
You've got the correct MIDI channels selected on both PT and the DR?
Old 03-06-2012, 01:09 PM
midsummermagic1111 midsummermagic1111 is offline
Thumbs up Re: Boss DR-880 (Drum Machine) and Pro Tools
plug dr880 into usb port download driver from boss website/restart computer/power on 880/makesure driver shows up and is functioing correctly in device manager/start pro tools/create midi track/boss dr880 should now be on your i/o dropdown menu/choose dr880 channel 10 for in and output setting(default channel on dr880,refer to manual page 126)/record enable midi track......hope this helps i had same problem,but kind of have it worked out
Old 03-08-2012, 01:13 AM
Hi midsummermagic1111 !
Thanks a lot you for your help !
I'm away this week, means I can't try what you advised me to do.
I'll try it asap and tell you if it has solved my issue !
THANK YOU AGAIN, and that's a forum ok but I don't consider that's "normal you help others with their issues", that's very kind of you !!! So a big Thanks !
Old 03-14-2012, 08:11 PM
RegenerationMix RegenerationMix is offline
oddly enough,my workaround was I took my 880 and sampled all the sounds in it and then put them into my drum VI Idrum and into structure free. Made it much easier to use the sounds.
took me an evening to resample all the sounds and get them internally. But i find i use the sounds more than i use the drum machine via midi.
just a thought.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 06-23-2012, 08:00 AM
homer14z homer14z is offline
i have a similar problem trying to get pro tools to play my drum machine and other instruments. (very new to pro tools and computer recording/midi in general so please be gentle). I have been searching forums and the net but haven't found the answer yet. I have a DR 660 and a Korg M50. I can see the notes played on midi in the software. I can even get pro tools to play the notes on the software instruments, but I can't get play back on any external instruments. I assume this is possible? Any help or ideas pointing to answers would be appreciated. Thanks
Old 06-28-2012, 08:50 PM
do you have the external midi devices set to a specific midi channel ?
Do you have the pro tools track set to that midi instrument and on the midi channel for it?
Chris
Setup a drum machine (Boss DR-880) in Pro Tools : Please help ! New Perspective! Windows 6 03-06-2012 01:18 PM
Pro Tools MP 8.0.1 with BOSS DR770 Drum Machine controller SoMedia Pro Tools M-Powered (Win) 1 05-07-2011 08:42 PM
Trouble using Boss DR 880 drum machine with pro tools. Zombehr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-08-2010 05:27 PM
Pro tools le and Boss dr 670(drum machine) zory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-05-2010 11:52 PM
questions with syncing up my boss drum machine johnnymojo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-02-2004 02:47 PM
