Old 07-06-2010, 09:07 AM
greglarson greglarson is offline
Exclamation cant figure out how to assign the optical in to a track?
Im using a focusrite octopre with my pt le 7 system and 002 factory board...I'm using an optical cable to connect the two but I cant figure out how to assign this as the input on a track. If anyone could help i'd really appreciate it, my kick and snare sound is waaay to digital sounding atm.
thanks
Old 07-06-2010, 09:25 AM
fsb1 fsb1 is offline
Default Re: cant figure out how to assign the optical in to a track?
with 003 the first two digital inputs are SPDIF, rest ADAT
Hope that helps
Mix + Control, Studio One V2 Professionel
Old 07-06-2010, 11:00 AM
First off, go into PT>Setup>Hardware and make sure that Optical is set to ADAT. On the same page, set Clock Source to Optical(or you will get clicks and pops). Next, go to Setup>IO...>Input tab and hit the Default button(so now you should see a grid with 18 inputs with 9 thru 16 labeled ADAT1, ADAT2, etc.). If the Octopre has a button for selecting internal or external clock, set it to Internal(so it will act as the master clock). Also, make certain the lightpipe "cable" is seated at both ends(those little plastic connectors are not the best.....)
Create and Assign New Track from Track ZEROPRO Windows 2 12-05-2011 09:15 PM
how to assign a plugin to a midi track shoog MIDI 3 12-01-2007 07:50 AM
Audition track assign in 7.1cs4 CD Productions Pro Tools TDM Systems (Mac) 4 03-22-2006 04:44 PM
Can't figure how to fade track gstockton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-08-2005 02:32 PM
assign one voice per track mario Pro Tools TDM Systems (Mac) 3 05-08-2000 12:31 AM
