Old 05-06-2000, 05:47 PM
mario mario is offline
Default assign one voice per track
Is there a way to assign one voice per track with a command?, after adding many tracks some of them end up sharing one voice when there are still several free. I need to know if there is a way to assign them without having to go one by one.
Thanks
Mario de Arce
Blue Blood Audio
http://www.bluebloodaudio.com
Old 05-07-2000, 06:10 AM
Cawbaby Cawbaby is offline
Default Re: assign one voice per track
I agree Mario, I don't think there's a
key command but there definitly should be.
Maybe there is in 5.0. I'm still using 4.3.1.
Dr. Caw Recording
www.drcaw.com
Old 05-07-2000, 10:24 AM
Compression Records Compression Records is offline
Hold option-command while you select voice 1 in the voice pop-up menu of any track. All tracks will be assigned a different voice (up to availability) in ascending order from 1 up. If you select a voice number other than 1 (say, 13), the voice assignment starts from that voice number up (from 13 up).
Marco Marinangeli
Magelic Productions, Inc.
Compression Records
http://www.compressionrecords.com
Marco Marinangeli
Compression Records
Old 05-08-2000, 12:31 AM
Yes Marco, but that's only in V5.0 and above.
Rail
Recording Engineer
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Create and Assign New Track from Track ZEROPRO Windows 2 12-05-2011 09:15 PM
Can't assign audio to new track for mixdown LSJ Pro Tools TDM Systems (Mac) 1 02-09-2011 06:29 PM
cant figure out how to assign the optical in to a track? greglarson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-06-2010 11:00 AM
how to assign a plugin to a midi track shoog MIDI 3 12-01-2007 07:50 AM
Audition track assign in 7.1cs4 CD Productions Pro Tools TDM Systems (Mac) 4 03-22-2006 04:44 PM
