Old 12-24-2005, 02:58 PM
cletus cletus is offline
Default Syncing Drum Machine to Pro Tools
Hey there everybody, not new to recording but just starting to get into midi. I wanted to know how to sync a drum machine to PT7. I'm going line in to my 002 from the drum machine as well as midi. Pro tools does not automatically see the hardware so in OSX I attach new midi device to the 002 in audio midi set up, but from there how do I set protools as the master for MTC?
Old 01-04-2006, 06:44 AM
4string 4string is offline
Default Re: Syncing Drum Machine to Pro Tools
Cletus - did you ever figure out how to sync your drum machine with Pro Tools? I am a newby trying to figure out the same issue. I would like the drum machine to start playing when I 'play' in Pro Tools
Thanks
4string
Old 01-04-2006, 07:52 AM
DigiTechSupt's Avatar
Open the Session Setup window, check the option for MTC to Port, then choose the port/device from the drop down box that you would like to send MTC to.
Also - double check that your session start time is appropriate and that frame rates match that of your drum machine - you can find these in the upper right of the Session Setup window.
More info can be found in the Synchronization section of the Pro Tool Reference Guide, which you should find under the 'Help' menu in Pro Tools.
Avid Audio Tech Support
Support FAQ
syncing external drum machine yorgo Pro Tools 9 2 02-25-2014 02:30 PM
Trouble Syncing Drum Machine with Pro Tools scottrolfs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-24-2014 06:49 PM
syncing external drum machine MPB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2013 11:54 AM
Syncing drum machine to PT? Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2005 12:05 PM
questions with syncing up my boss drum machine johnnymojo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-02-2004 02:47 PM
