Old 07-22-2006, 08:09 PM
gwattaloopy1 gwattaloopy1 is offline
Default is the search function not working?????????
it seems like no matter what you search, it gives you every recent post regardless of what you asked for. is it only me?
Old 07-22-2006, 08:14 PM
Default Re: is the search function not working?????????
if you have to first selection to in the "subject and body", it will pick out everything with the words u used in the entire thread, so something like 002 will pull up about everything, narrow it down to minimum or try just the subject selection, thats how i usually do it to thin it out some.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 07-22-2006, 08:32 PM
is it only me?
No, like myself, there have been a number of cases this exact situation has happened. But as guitardom says narrowing down the search, does sometimes turn results, but there has been times when the original problem still persists.
filosofem
Aaron Mulqueen - 001 HD Native
Old 07-23-2006, 06:35 AM
spkguitar's Avatar
Make sure that if you are searching for a phrase (anything more than one word), that you surround it with quotes.
Searching for power harness is not the same as searching for "power harness". The first will search for any posts with the word power and any posts with the word harness, where the second will only search for the phrase power harness.
Longer phrases, if not surrounded by quotes, would definitely not return the results you are looking for. Bounce to disk without the quotes would return all posts with the word to, which would end up being just about any post, but "Bounce to disk" would only return posts with the whole phrase Bounce to disk.
If you are looking for posts with more than one word or phrase, put a + sign in front of each word (or phrase).
+"Bounce to disk" +MP3 would return any posts that have both the phrase Bounce to disk and the word MP3.
Using the - sign in front of any word would exclude posts with that word. +"Bounce to disk" -MP3 would return any posts that have the phrase Bounce to disk but exclude any posts with the word MP3.
This information is available on the search page from a link called "Advanced Search Tips".
Old 07-23-2006, 11:36 AM
+"thanks" -alot
Avid Scorch for iPad in-app search function not working mbulaong2002 Avid Scorch (iOS) Forum 3 07-11-2012 04:48 AM
Problems with search function in ver 1.1 billunatic Avid Scorch (iOS) Forum 4 01-05-2012 11:45 AM
Search function Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-01-2005 05:35 AM
What's the trick to using the SEARCH function ? bH101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-07-2004 01:27 AM
What's up with the DUC search function? Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2003 02:01 AM
