Old 05-12-2004, 11:22 PM
Mikchek Mikchek is offline
Default WTF My plugins don\'t work anymore..PLEASE HELP
I dont know if it is since the 32Track upgrade or what but when I try to process a plugin on a track file it doesn't work....the real time plugs work just fine but the AUdiosuite don't......can somebody please helpg me.
Mikchek the Emcee
www.mikchek.com
Old 05-13-2004, 01:39 AM
Homebelly Homebelly is offline
Default Re: WTF My plugins don\'t work anymore..PLEASE HELP
If your on OS9 with the 32 trk beta then the fix is to either not process using audiosuite plugs when the transport is running,,or to swap the 32 trk beta DAE with the old one,, I think i have this right,, it seems like forever since i was on PT5,,
Old 05-13-2004, 02:54 PM
MoreMeintheMonitors MoreMeintheMonitors is offline
What do you mean by 'not working'? Are they not showing up or are they not working when you try to process?
Typically when someone says 'it's not working', it usually because they do not have 'use in playlist' highlighted in the Audiosuite plug-in window.
Old 05-27-2004, 07:10 AM
Well I figured out that it is something with the 32 track Beta because I totally reinstalled the program and it worked just fine....but when i install the 32 track update it stops working......when i say not working I mean that when I highlight a wav and attempt to process a AudioSuite plugin it doesn't do anything to the wav...no visual or sound change.......
Mikchek the Emcee
www.mikchek.com
Old 05-27-2004, 07:12 AM
I have tried to put the old DAE back and it still is showing me no love. for some reason I remember the Audiosuite working when I first installed the 32 track beta...and why the hell is the 32track still a beta......I guess that is where 6 comes in......as for running it while the transport is running I'm actually not doing it while the transport is running....
Mikchek the Emcee
www.mikchek.com
Old 05-27-2004, 07:15 AM
BINGO...you hit it right on the button....i went back and I didn't have "use in playlist" highlighted....thanks a lot....
Mikchek the Emcee
www.mikchek.com
Can't work in 88.2 anymore on PT9? nickbradbury macOS 6 03-13-2011 06:07 PM
M-box mini doesn't work anymore. chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-25-2008 09:34 PM
I don't ses my plugins anymore Digital Network 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-29-2008 10:54 AM
itunes doesn't work anymore?!?! ichbin Pro Tools TDM Systems (Mac) 5 01-09-2006 05:38 PM
PT 5.01 + OMS + Logic 4.5 don't work anymore! smcoptyltd Pro Tools TDM Systems (Mac) 4 10-17-2000 10:13 AM
