Error (-6086) on Windows XP PT LE 7.3.1
Hello,
I am trying to use ProTools 7.3.1 Mbox2 on a Windows computer - a Dell 690 workstation with Windows HP Pro SP2. I keep getting the following error message: "The operating system held off interupts for too long. If this occurs frequently, try increasing the "H/W Buffer Size" in the Playback Engine Panel. (-6086)." After following all your guidelines (except throwing out my quad-core processors) and spending hours, I still have the same problem, even with a single mono track being played. I narrowed this down to the behaviour of Mbox and Mbox2 ASIO driver, since M-Powered ProTools LE with BlackBox works on the same computer with a standard setup works like a dream. However I borrowed M-Povered and BlackBox and need to decide what to do with MBox2. Can anybody help? |
Re: Error (-6086) on Windows XP PT LE 7.3.1
I found this information ins one of your previous posts. Is it still valid?
There have been instances where certain USB ports in the same PC cannot adequately provide enough power across the USB bus to run the Mbox2 properly. Sometimes this effect is limited to only one or a set of USB ports in the same computer. This is especially evident on the Macbook, and the Macbook Pro, where only the front USB port can be used to run the mBox USB devices. I would imagine might be experiencing this same problem with your Dell, so try using different USB ports.
yes, the information is still valid.
Thank you very much for your advice - I tried all permutations, even connecting a powered USB hub between, to provide the power, but no success. Everything points to the drivers, since other audio software that behaves normaly when it uses built-in audio card starts having problems with the playback if I select it to use ASIO driver. |
I am contemplating selling MBox 2 and getting 003 Rack?
What are the chances that a firewire interface would show the same problem? |
I'm not sure of the things you have tried, but I would include:
- record to a different HD - changing out the USB cable to the Mbox2. - disabled the speedstep in the bios - run the hotfix. If you basically have a "Digi OK" system, you should be able to iron out your problems. As far as firewire interfaces, they can also have the -60xx problems. I've had a problem with my IBM laptop and a Digi-qualified Pryro fireware PCMCIA card. I was getting the -6086 errors. I replaced the card and still got the same errors. I changed to another cheaper firewire non-qualified card and it worked better. But it didn't completely stop the errors until I changed some power setting for the PCI bus... I really don't know which one it was, but it has been great since then. So, I would make sure all the "save power" settings are diabled before selling your interface.
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz |
Have you disabled your network adapters in the device manager and ran msconfig?
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4 Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800 Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667 Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1 |
Thanks for a kind message John, but I spent so much time on this problem without getting anywhere that I can not justify spending another two weeks chasing my tail.
It is like back in the nineties when computers and music were more like black magic. I would prefer playing in front of the audiance anytime, even if they booed me off stage - at least I would know I was the one to blame. Yes, I have first tried every thing Digidesign recommends, but there was no difference - the playback would last five seconds more or three seconds less, but there was no regualarity so I was trying the wrong things. The only things I didn't switch off were graphic card, keyboard and mouse, and only thing I have achieved was feeling like an idiot, since none of the Digidesign recommendations were relevant. Your suggestion that the problem may come from not enough power through USB makes sence, since M-Audio's Black Box has its own power supply and it works witout a glich. But I tried all the USB ports on the computer without effect. There is an option of getting a USB card which can source enough power, but the ones that can cost almost as much as MBox. And it would be a shot in the dark - after all I do not have a confirmation from Digidesign that this is the root of the problem (the error message goes on about interupts and buffer size, but in my case it is wrong). Unless Digidesign comes up with some kind of a solution, MBox 2 will hit eBay, and may the new owner have more luck than me. Thanks, Dusan |
There's one solution that I've forgotten about, that I haven't seen you mention doing.
Have you made sure that all of the USB root hubs are set to not "Allow the computer to turn off this device when not in use"? Having that option turned on has been known to cause errors with the mbox units in the past. That's the only other thing I can think of at this point. And if an internal USB card is going to cost as much as the mBox, you're shopping at the wrong computer stores.
I have switched off anything that is related to clever power management and it still didn't help. Quote:
I have found these that would definitely source enough power: http://www.digi.com/products/usb/usbplusseries.jsp but the price is between EUR 130 and EUR 180 which is between $200 and $250. If anybody has something similar but for less money - please let me know. I would like to get to the bottom of it, but it doesn't make sence to spend so much for something that might not be the solution. |
upgraded to Windows 7, now I keep getting 6086 error. worked on XP | awthentik83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-07-2010 03:31 AM |
Error 6086 | arnocekkert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-21-2008 02:00 PM |
Error -6086 ??? | JDMah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-20-2006 06:26 PM |
6086, Windows, H/W Buffer | DJRAFT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-11-2005 09:15 AM |
6086, Windows, H/W Buffer | DJRAFT | Pro Tools TDM Systems (Win) | 0 | 03-12-2005 09:11 PM |
