Old 02-12-2002, 09:03 PM
san mehat san mehat is offline
Default Bounced Audio plays slower on CD/pc??
Greetings,
I have a TDM/mac system with a 1622 board (software ver 5.0.1) and am having a problem when bouncing my final mix. The mix sounds fine when bouncing, but when I either burn to CD (using Masterlist CD) or transfer the audio to my PC, the playback is slower...
My session was recorded at 44.1 KHZ / 24 bit, and is bounced to stereo, 16 bit, 44.1 khz.. (i've tried converting to wav, and leaving it in sd2 format but no change).
Any help would be appreciated
-san
Old 02-12-2002, 09:45 PM
BDWillis BDWillis is offline
Default Re: Bounced Audio plays slower on CD/pc??
A couple of questions… 1) Is there an external clock (Aardsync, Nanosyncs, etc) connected to the system that was sending out 48k clock? 2) Is there a DAT machine that defaults to 48k connected to the I/O, with those channels set to digital in? If the answer's yes to either of those, you could have set the session's sample rate at 44.1 and STILL recorded 48k files (yep, been there, done that… aaarrggghh…). The session will play back at the proper speed as long as the external clocking source is hooked up, but as soon as you take the files to another playback device, they'll be slow.
I got around it by going analog out of my screwed-up PT session into a DAT machine & sending a S-PDIF line from the DAT to my LE Toolbox PT rig to print mixes(could have printed to DAT, but would rather create SDII files directly on the little system). Hope this helps.
Warmest Regards,
Brian
Old 02-12-2002, 10:13 PM
Brian,
Thank you very much for the reply.. as it turns out my MOTU midi timepiece had indeed defaulted back to it's factory defaults... and was spewing out a 48KhZ clock...
Hope you like Heineken... it's on the way..
-san
Old 02-12-2002, 10:53 PM
san,
As a musician buddy once said, "You're not a REAL engineer until you mess something up!". Welcome to the club — cheers & bottoms up!
Warmest Regards,
Brian
Pro Tools 9 Session Plays Slower With Optical Profier 26/26 toolgirl macOS 3 02-01-2011 12:49 AM
Bounced files playing back slower unkljojo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2007 04:45 PM
Sync problem? Bounced WAV plays too fast! MrJoshua 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-03-2006 11:23 AM
Bounced File Plays Back Slower Luky7Music Post - Surround - Video 2 09-11-2004 08:40 AM
cd plays slower..please help.. Karrot24 Tips & Tricks 5 03-09-2001 01:19 AM
