Old 03-02-2005, 07:20 PM
yotam agam yotam agam is offline
Default Presonus Digimax and 192 digital IO
Just about to get 2 Presonus DigiMax96 and 192 digital IO which has to TDIF nput in the back.
Question:
Is the DM008 - AES/EBU Breakout Cable For Digidesign 192 I/O will carry ALL 8 Channels 96K into ProTools?
Old 03-03-2005, 04:53 AM
mixer mixer is offline
Default Re: Presonus Digimax and 192 digital IO
no 96k is only supported by spdif or aes outs of the digimax. only two channels..the optical output will do 8 channels at 48k.
www.garyvandy.com
Old 03-03-2005, 11:24 AM
Brad Cobb Brad Cobb is offline
The easiest way is to use the AES breakout on the Digimax, they sell one that is a 25pin d-sub for PT.
Then just use your AES I/O on the Digital 192. That breakout also includes a d-sub for your 8 digital outs.
bc
Old 03-03-2005, 01:18 PM
DigiTechSupt's Avatar
Or you could stick with ADAT format and enable real-time sample rate conversion in the HW setup for 96kHz compatibility.
best,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 03-03-2005, 02:17 PM
Yea, the SRC works and sounds great. Having said that, the Presonus
Digital AES Cable allows 8 wide w/out SRC at 88.2
and 96k with any of the 192 I/Os. I think there is also a benefit
to clocking the Digimax to your I/O or master clock.
bc
Presonus Digimax hmsbass Third Party Interfaces 7 07-15-2013 08:49 AM
002 plus Presonus DigiMax D8 tchipman Pro Tools 9 1 10-19-2012 08:38 PM
rme adi 8 pro or presonus digimax batti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-08-2002 01:06 AM
PRESONUS Digimax anyone? digigirly Tips & Tricks 2 11-26-2001 08:37 PM
anyone use the presonus digimax? Mike F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-23-2001 04:41 PM
