  #31
Old 01-09-2020, 07:09 AM
off the wall's Avatar
Default Re: Mac Pro 5.1 Mojave - what GPU cards work?
Originally Posted by Padje View Post
Thinking of updating gpu to, but in the same boat considering power for videocard in combination with HDX and UAD
Could you elaborate with cable you used ? And where to buy ?
Thanks a heap !
I'm currently running power for the HDX card off one of the unused SATA bays. But the optical bay is even slicker and I'm going to swap over the next time I have the Mac Pro out of the rack. You should have the molex connectors for the optical bay power included with your HDX card.
See this post for my current setup:
https://duc.avid.com/showpost.php?p=...3&postcount=34
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2019.12. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
  #32
Old 01-09-2020, 08:04 AM
Padje Padje is offline
Lovely ! Thank you very much.
  #33
Old 01-09-2020, 08:36 AM
The golfer The golfer is online now
@Off the wall
Thanks for the link and tip. I am curious to know if the mapro mid 2012 power supply is enough to power both the HDX and RX 580 at the same time without too much heat, but will definitely look into this.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Will the cards in my G5 work in a new Mac Pro? megahurt Pro Tools TDM Systems (Mac) 8 10-09-2009 05:04 AM
Do all MIX Core cards work in G4s? Sensei Pro Tools TDM Systems (Mac) 0 09-10-2004 06:52 PM
D24...will my cards work in a G4? Allbaldo Pro Tools TDM Systems (Mac) 4 10-28-2002 07:48 AM
Do firewire cards work with PT? Allbaldo Pro Tools TDM Systems (Mac) 8 09-09-2002 08:00 PM
PT Cards work in all countries? SteveGarman Pro Tools TDM Systems (Mac) 1 03-10-2001 10:18 AM
