Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-22-2018, 01:09 AM
Raoul23 Raoul23 is offline
Default Apple Crash Report
Anyone here able to understand what they mean?
I had one keep coming up when i try to open a session, but i havent a clue what it all means.
If i posted it here, would anyone shed some light
Thanks in advance
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 02-22-2018, 03:31 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Apple Crash Report
Thanks in advance
Post it up. it usually says which thread is the cause and the thread will often mention what is causing the panic, often a plugin etc.
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-22-2018, 03:53 AM
Thanks Chris i'll post it up later :)
Raoul Crane
Old 02-22-2018, 08:40 AM
Originally Posted by crizdee View Post
Chris
Here it is Chris it was to large to paste in here so had to drop box a link to it
https://www.dropbox.com/s/wf8wugzkm1...eport.rtf?dl=0
Thansk Raoul
Raoul Crane
Old 02-22-2018, 09:08 AM
crizdee's Avatar
Thansk Raoul
Waves shell 9.3
I'm using a mixture of waves 8 and waves 9. i know some of the more recent plugs from Waves won't run on Lion. best use the 8 versions if you can. i only use 9 versions where versions 8 are available.
I have to install versions 8, then remove the waveshell 8 from the digidesign plugins folder then install version 9.
Then remove all the versions 9 plugins from the "waves 9 plugins folder" that i use as version 8. then put the version 8 waveshell back into the Digidesign plugins folder!
Phew still with me a little complicated but it works
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-22-2018, 09:12 AM
I got ya chris thanks. Does it say what waves plugin crashes it
Raoul Crane
Old 02-22-2018, 10:33 AM
crizdee's Avatar
No because waves uses a shell to house their plugins in pro tools, but it will be one of the version 9 or the waveshell itself is not compatible. it might be too new a version etc. i use waveshell 9 as mentioned above but don't think its the latest version.
are you using all version 9 waves?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-22-2018, 10:39 AM
All version 9 buddy, this is on my hard drive running Maverick. With Lion the sessions open up fine. Strange as I use the same selection of plugins for my mixing but some sessions open fine 1 or 2 don’t
Raoul Crane
Old 02-26-2018, 02:26 AM
Ok i've gone to my Lion partition now from maverick because 2 sessions were not opening in Maverick. These sessions will now not open in Lion.
Here is a crash report which which made my Mac reboot. I didnt get time to copy the first one but it mentioned soundtoys echoboy alot.
Anyone understand this one.
Interval Since Last Panic Report: 967205 sec
Panics Since Last Report: 7
Anonymous UUID: 3D625DCB-D2E5-4952-A15A-CE716892B50D
Mon Feb 26 10:22:44 2018
Panic(CPU 1): Unresponsive processor (this CPU did not acknowledge interrupts) TLB state:0x0
RAX: 0x00000000ffffffff, RBX: 0xffffff803c983700, RCX: 0x0000000003520000, RDX: 0xffffff803cd57900
RSP: 0xffffff838cebbf10, RBP: 0xffffff838cebbf10, RSI: 0xffffff803c983700, RDI: 0xffffff803cbb0000
R8: 0x000000c6f09ea935, R9: 0x000000c6f09ea935, R10: 0x0000000000000000, R11: 0xffffff833c67d000
R12: 0xffffff7f818e12a6, R13: 0xffffff803c983700, R14: 0xffffff803cbb0000, R15: 0xffffff803c841800
RFL: 0x0000000000000246, RIP: 0xffffff7f818e3121, CS: 0x0000000000000008, SS: 0x0000000000000010
Backtrace (CPU 1), Frame : Return Address
0xffffff8383015f50 : 0xffffff80002c9a7c
0xffffff8383015f80 : 0xffffff80002c48d0
0xffffff8383015fd0 : 0xffffff80002da712
0xffffff838cebbf10 : 0xffffff7f818e12e3
0xffffff838cebbf40 : 0xffffff800063fc01
0xffffff838cebbf70 : 0xffffff800023dbbc
0xffffff838cebbfb0 : 0xffffff8000820057
Kernel Extensions in backtrace:
com.apple.driver.AppleIntel8254XEthernet(2.1.3b1)[E1AA3296-4171-3DA5-9F95-FC0EA9441B20]@0xffffff7f818da000->0xffffff7f818f4fff
dependency: com.apple.iokit.IONetworkingFamily(2.1)[2FCC16E1-34AB-3908-98BD-CCBFA56FFDCE]@0xffffff7f815c1000
dependency: com.apple.iokit.IOPCIFamily(2.7)[5C23D598-58B2-3204-BC03-BC3C0F00BD32]@0xffffff7f8082b000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
11G63
Kernel version:
Darwin Kernel Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64
Kernel UUID: FF3BB088-60A4-349C-92EA-CA649C698CE5
System model name: MacPro3,1 (Mac-F42C88C8)
System uptime in nanoseconds: 854767397258
last loaded kext at 85741833385: com.apple.driver.AppleUSBCDC 4.1.22 (addr 0xffffff7f8176c000, size 16384)
last unloaded kext at 146950875483: com.apple.driver.PioneerSuperDrive 3.0.6 (addr 0xffffff7f82102000, size 12288)
loaded kexts:
com.paceap.kext.pacesupport.snowleopard 5.9.1
com.digidesign.iokit.DigiDal 10.3.10d4
com.apple.driver.AppleBluetoothMultitouch 70.12
com.apple.filesystems.msdosfs 1.7.1
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.filesystems.autofs 3.0
com.apple.driver.AudioAUUC 1.59
com.apple.driver.AppleUpstreamUserClient 3.5.9
com.apple.driver.AppleMCCSControl 1.0.33
com.apple.driver.AppleHDA 2.2.5a5
com.apple.driver.AppleMCEDriver 1.1.9
com.apple.iokit.IOUserEthernet 1.0.0d1
com.apple.GeForce 7.3.2
com.apple.iokit.IOBluetoothSerialManager 4.0.8f17
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AudioIPCDriver 1.2.3
com.apple.driver.ApplePolicyControl 3.1.33
com.apple.driver.ACPI_SMC_PlatformPlugin 5.0.0d8
com.apple.driver.AppleLPC 1.6.0
com.apple.driver.CSRUSBBluetoothHCIController 4.0.8f17
com.apple.iokit.SCSITaskUserClient 3.2.1
com.apple.driver.XsanFilter 404
com.apple.AppleFSCompression.AppleFSCompressionTyp eDataless 1.0.0d1
com.apple.AppleFSCompression.AppleFSCompressionTyp eZlib 1.0.0d1
com.apple.BootCache 33
com.apple.iokit.IOAHCIBlockStorage 2.1.0
com.apple.driver.AppleAHCIPort 2.3.1
com.apple.driver.AppleIntelPIIXATA 2.5.1
com.apple.driver.AppleIntel8254XEthernet 2.1.3b1
com.apple.driver.AppleUSBHub 5.1.0
com.apple.driver.AppleFWOHCI 4.9.0
com.apple.driver.AppleUSBEHCI 5.1.0
com.apple.driver.AppleUSBUHCI 5.1.0
com.apple.driver.AppleEFINVRAM 1.6.1
com.apple.driver.AppleACPIButtons 1.5
com.apple.driver.AppleRTC 1.5
com.apple.driver.AppleHPET 1.7
com.apple.driver.AppleSMBIOS 1.9
com.apple.driver.AppleACPIEC 1.5
com.apple.driver.AppleAPIC 1.6
com.apple.driver.AppleIntelCPUPowerManagementClien t 195.0.0
com.apple.nke.applicationfirewall 3.2.30
com.apple.security.quarantine 1.4
com.apple.security.TMSafetyNet 8
com.apple.driver.AppleIntelCPUPowerManagement 195.0.0
com.apple.driver.AppleBluetoothHIDKeyboard 160.7
com.apple.driver.AppleHIDKeyboard 160.7
com.apple.driver.AppleMultitouchDriver 231.4
com.apple.driver.IOBluetoothHIDDriver 4.0.8f17
com.apple.kext.triggers 1.0
com.apple.driver.AppleSMBusController 1.0.10d0
com.apple.driver.DspFuncLib 2.2.5a5
com.apple.driver.AppleUSBAudio 2.9.0f5
com.apple.iokit.IOFireWireIP 2.2.5
com.apple.driver.AppleHDAController 2.2.5a5
com.apple.iokit.IOHDAFamily 2.2
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 32 GB, SMC 1.25f4
Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
Memory Module: DIMM Riser B/DIMM 1, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser B/DIMM 2, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser A/DIMM 1, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser A/DIMM 2, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser B/DIMM 3, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser B/DIMM 4, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser A/DIMM 3, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Memory Module: DIMM Riser A/DIMM 4, 4 GB, DDR2 FB-DIMM, 667 MHz, 0x802C, 0x333648463531323732465A36363748314436
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GT 120, sppci_displaycontroller, Slot-1
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@7,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@7,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@8,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@8,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@9,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@9,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@10,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@10,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@11,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@11,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,6,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,7,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,8,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,9,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,10,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,11,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-4@12,12,0
Serial ATA Device: KINGSTON SV300S37A120G, 120.03 GB
Serial ATA Device: ST31000528AS, 1 TB
Serial ATA Device: ST3250824AS P, 250.06 GB
Serial ATA Device: Kingston SSDNow V Series 64GB, 64.02 GB
Parallel ATA Device: PIONEER DVD-RW DVR-112D
USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0xfd300000 / 4
USB Device: Nocturn Keyboard, 0x1235, 0x0012, 0xfd320000 / 7
USB Device: iLok, 0x088e, 0x5036, 0xfd340000 / 6
USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0xfd310000 / 5
USB Device: DataTraveler 2.0, 0x0951 (Kingston Technology Company), 0x1603, 0xfd200000 / 3
USB Device: Ultra, 0x0781 (SanDisk Corporation), 0x5581, 0xfd100000 / 2
USB Device: Command8, 0x0dba, 0x8000, 0x3d200000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: built-in_hub, 800mbit_speed
Raoul Crane
Old 02-26-2018, 02:35 AM
got the session crash report this time as it done it again
https://www.dropbox.com/s/7vrbosbw48...eport.rtf?dl=0
Raoul Crane
Crash with PT 10.3.3 (crash report inside) powerjoe Pro Tools Software (Mac) 8 01-22-2013 10:33 AM
Crash Report Help Please joji Pro Tools TDM Systems (Mac) 3 03-21-2010 02:11 AM
Crash report GS-DK Pro Tools TDM Systems (Mac) 2 01-20-2010 01:47 AM
Best Crash Report ever!! suicune Pro Tools TDM Systems (Mac) 10 07-14-2009 12:58 PM
Major Crash with PT 7.3 cs5 crash report included RuffJazzRecords Pro Tools M-Powered (Win) 0 02-09-2008 12:43 PM
