Old 02-10-2009, 06:24 PM
christopherlennon christopherlennon is offline
Default How to copy Plug In Settings from one computer to another?
I have waves on computer #1; It has many custom settings which can be found by clicking on the load button.
I just purchased computer #2, and have installed protools and the wave plugins- now I want to be able to access all the previous customized settings i created for the waves plugins in computer #1 on computer #2.
Any one know which file I copy from #1 to #2??
Thank You.
“It’s really not about frantically looking for that “elusive” sound. It’s about exhibiting a calm focus in order that the sound may come to me.” -LD
Old 02-10-2009, 08:17 PM
andydunham andydunham is offline
Default Re: How to copy Plug In Settings from one computer to another?
I THINK that this location : HD>Library>Application Support>Digidesign>Plugin Settings is where your presets and your customized presets will be saved. I believe if you want to copy them to another computer, you should be able to simply copy the one(s) you want to a flash drive etc, and put them in the same folder mentioned above, on the 2nd computer. If this isn't correct, maybe someone else can chime in.
Old 02-11-2009, 12:55 AM
youngas75 youngas75 is offline
That's my school of thought too.
6 x HDX
21 x Vanilla
D-Command ES
S6 M10
SSL Duality, AWS924, AWS948, Nucleus
All Mac
Old 02-11-2009, 05:45 AM
Corto Corto is offline
Yes, it's the default way to save plug-in settings and I believe that Pro Tools don't authorize you to choose another.
I don't know Waves plugs but if they are like TL Space, for example, then you have a special file where your preset are.
In most cases HD>Library>Aplication Support
Good luck
Old 02-11-2009, 09:37 AM
Thank you all for your responses-
I am aware of those locations, but the specific file?
I haven't clicked on a file/folder that specifically has all the settings there
that I programmed-
Do you guys know which specific file?
Thank you again-
Old 02-11-2009, 10:37 AM
I don't have the Waves plugins myself, but I would think the process for saving them would be the same. I just opened a session, used the default PT EQ 3.0 and saved an EQ setting as "TEST." Under HD>Library>App Support>Digidesign>Plugin Settings>EQ 3.0 I now see the same setting I saved within Pro Tools. It sounds like you just need to find the correct folder where your waves plugins are and the settings you save SHOULD be in there. I don't see why any plugins would be in a different location than the one listed above. Hope this helps.
Question about plug-in copy settings kierkegaard Pro Tools 10 1 05-01-2013 01:37 PM
Copy plug-in settings to audiosuit tokolosh Post - Surround - Video 11 10-12-2009 03:42 AM
Melodyne plug copy settings from one harmony to another? crizdee Pro Tools TDM Systems (Mac) 7 04-15-2009 10:09 AM
How Do I Copy Plug-In Settings to a Different Trac morepiepop Pro Tools TDM Systems (Win) 2 11-20-2003 11:36 AM
how do you copy plug in settings surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-15-2001 07:52 PM
