Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 03-13-2018, 02:31 AM
jimmivalentino jimmivalentino is offline
Default Track won't re-activate - 2018.1
Any solutions or workarounds? This is happening ALL the time to me, hopefully it's been fixed in 2018.3.
Old 03-13-2018, 07:51 AM
climber climber is offline
Default Re: Track won't re-activate - 2018.1
Never seen or heard of this. Plus no information about platform or OS! 🤷🏽*♂️
Al Hospers
bass, vocal, composer, engineer
CleverSounds Recording
OS X Mojave, Late 2013 MacPro, 6 core, 32 GB RAM, Orion Studio , PT2018.10, Slate MTi, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 03-15-2018, 01:08 AM
Nearlymen Nearlymen is offline
I've experienced something similar in 2018.3, running in win 8.1 but it's very intermittant. Basically I put a newmidi instrument in a track in my session created from my template , record midi into it and its fine. Then Save the session, open it again and the midi is solid grey colour. The tracks not frozen or inactive, it just doesn't work. But if I then open a new instrument track and transfer the midi to that, it works fine and I just delete the original track and proceed like nothings happened. I suspect, although havn't looked at it yet (too busy) ! is that the problem is in my template file. So see if any of this sounds familiar and if this little workaround helps !
Also maybe try editing your template and re-saving it in the version your using ?
Just ideas !
Cheerio
Clive
Old 03-15-2018, 10:22 AM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
I see this on Instrument tracks as well, sporadically. On my system what happens is that Pro Tools forgets the Midi Output Routing (pulldown box at the top of the track just below Midi Input Routing pulldown box) and resets it to "none". Easy but annoying fix, just reset the output to the correct VI or whatever you're using and the track comes back to life.
Peter
Gypsy: PT Ultimate 2018.10, 12-core Mac Pro 3.46Ghz 64GB OS 10.13.6, HD Native, HD OMNI, HD I/O, 2 Artist Mix, EUCON 18.3, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, 2 1176s, Malone Design Works desk
Laptop: 10.13.4 MacBook Pro 2.8 Core i7, 16G, PT 12.8.2, RME FF800/TCO, Live 9
www.remotewest.com
@RemoteWest
Old 03-16-2018, 04:09 PM
K Roche's Avatar
K Roche K Roche is offline
Humm / maybe not much help But not seeing any of this with my system.
Make Inactive and Active, works fine on Audio, Instrument, and Aux tracks
Midi recording saving fine closing session and also quitting PT plays fine when relaunched .
Midi output routing stays as original.
Have you guys tried trashing PT preferences ?
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Apple 1TB HDD and PT sessions storage on Apple 2TB HDD--
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 03-16-2018, 04:12 PM
TNM TNM is offline
midi output issue is common.. you are actually the first person I am speaking to that doesn't have it!
what we need to determine is if the OP did indeed mean de activating and re activating, which works every time. or whether he meant things losing their midi output selections...
1) iMac Pro 3.2ghz 8 Core, 64GB Ram, 2TB SSD, OS 10.13.6, Caldigit TS3+ Dock, Startech USB-C raid enclosure w/ Crucial MX500 1TB x2, 1TB SSD-R G Tech x 2, Samsung 860 Pro 512gb Audio Drive in USB C Enclosure, TBolt Apollo 8 x 2, TI2 Desktop, MoxF6, tons more midi synths, PT 2018.7/Cubase9.5.
2) MBP 2.8ghz i7 quad, 16GB ram, 1TB SSD, OS 10.12.6, PT 2018.7, Logic 10.4.1,Internal Sound, TBolt SSD 512GB.
Old 03-16-2018, 04:24 PM
K Roche's Avatar
Interesting. I tend to work with audio a bit more than midi and I have not been working all that much in the studio since switching to 2018.1 and HS.
But I did open and close and reopen about 6 different sessions with midi on them today . I do have about 13 or 15 more previous sessions with a fair amount of midi on them, and will test opening and closing them tomorrow or the next day.
System :
Enjoy the Journey
.... Kev...
Track preset key command PT 2018 tomdiek Tips & Tricks 1 03-03-2018 12:52 PM
Freezing all outputs of a multichannel instrument track causes -9400 error 2018.1 noiseboyuk Pro Tools 2018 7 01-29-2018 01:48 AM
Cant activate a plugin if copied from deactivated track djani Pro Tools 12 4 07-13-2015 12:16 PM
Can't activate instrument track in PT8 session chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-08-2009 07:05 AM
