Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 01-17-2016, 11:26 AM
[email protected] nickey1016@gmail.com is offline
Default Importing audio from fl studio to pro tools express
Okay so I'm brand spanking new to pro tools software and recording on my own in general. I've been working in fl studio creating instrumentals. Now I'm trying to import the audio into pro tools to record vocals. For some reason when I play the imported audio the sound quality is horrible (its not my speakers or equipment bcuz it sounds great when playing from fl studio). Then when I try to record vocals while playing back the recorded vocals with the beat it sounds so distorted and static and the vocals sound so low you can barely hear them. But if I play the recorded vocals solo it sounds good and clear and at a great volume. Someone help please! I don't know much about technical things. First problem I had was the sample rate, I knew nothing about that. Then couldn't figure out why mic wasn't recording, it was bcuz I didn't choose correct output/input. I dont know about these things trying to learn. If you dont have the answer pls point me in the direction of vids that deal with importing audio and recording vocals. Thanks!
Old 01-17-2016, 12:25 PM
Ben Jenssen's Avatar
Default Re: Importing audio from fl studio to pro tools express
My first guess would be that the exported audio is distorted. How does the waveform look? I bet it's filling up the track, top and bottom. If so, try to turn everything down in FL and export again. IHTH.
Old 01-18-2016, 06:02 AM
I turned the volumes down on each track and yes that helped. Thanks! The mixer in pro tools only shows volume and panning is there a mixer in this program where i can control base, treble etc?
Old 01-18-2016, 06:14 AM
In the PT mix window you must insert an EQ plugin on the track to do that.
I think you should try and find some getting-started-w/PT videos on youtube.
Old 01-18-2016, 07:26 AM
Thanks so much
Pro Tools Express M-Audio Edition David Paul Lucas Windows 2 12-18-2015 06:02 AM
No Playback Audio from Pro Tools Express xoSidneyox Pro Tools 10 1 09-18-2015 05:35 PM
Studio Monitor Express uninstalled but engine still appears in Pro Tools TXDigi Artist Series 0 10-13-2014 09:27 PM
MC Control, Studio Monitor Express with Pro Tools HD marietto81cs Artist Series 3 10-04-2011 02:57 AM
Studio Monitor Express with Pro Tools 9|HD clusterer Artist Series 2 02-01-2011 02:35 PM
