Feature transfer error 7.3
Digi, ummm... uninstalled Pro Tools 7.1 cs10, installed 7.3 and installation did not complete for this error
Feature transfer error Feature: Program Files Component: PACE System Files File: F:\PTLE7.3_32851\Pro Tools LE Setup.exe Error: Incorrect function. Reinstalled 7.0 and uninstalled Pro Tools/Drivers/Database/MIDI Perferences 7.0 and reinstalled 7.3 installation did not compete for the same error. System details: < Processor > Model: 2x Dual Core AMD Opteron(tm) Processor 265 Speed: 1.81GHz Model Number: 2914 (estimated) Performance Rating: PR10856 (estimated) Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core Internal Data Cache: 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache: 2x 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size < Mainboard > Bus(es): PCI PCIe USB FireWire/1394 i2c/SMBus MP Support: 2 Processor(s) MP APIC: No NUMA Support: 2 Node(s) System BIOS: Phoenix Technologies, LTD ASUS K8N-DL ACPI BIOS Revision 1008 System: System manufacturer System Product Name Mainboard: ASUSTek Computer INC. K8N-DL Total Memory: 3.2GB ECC DDR-SDRAM Registered < Chipset 1 > Model: Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed: 2x 1005MHz (2010MHz data rate) Total Memory: 2GB ECC DDR-SDRAM Registered Memory Bus Speed: 2x 201MHz (402MHz data rate) < Chipset 2 > Model: Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed: 2x 1005MHz (2010MHz data rate) Total Memory: 2GB ECC DDR-SDRAM Registered Memory Bus Speed: 2x 201MHz (402MHz data rate) < Video System > Monitor/Panel: Plug and Play Monitor Adapter: RADEON X550 Adapter: RADEON X550 Secondary < Physical Storage Devices > Hard Disk: WDC WD360GD-00FLC0 (34GB) Hard Disk: WDC WD740GD-00FLC0 (34GB) CD-ROM/DVD: DVDRW IDE H16X (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) < Logical Storage Devices > Hard Disk (C:): 34GB (27GB, 79% Free Space) (NTFS) Audio (D:): 69GB (69GB, 100% Free Space) (NTFS) CD-ROM/DVD (E:): N/A < Peripherals > USB Controller/Hub: Standard OpenHCD USB Host Controller USB Controller/Hub: Standard Enhanced PCI to USB Host Controller USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub FireWire/1394 Controller/Hub: Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard: Standard 101/102-Key or Microsoft Natural PS/ 2 Keyboard Mouse: Microsoft PS/2 Port Mouse (IntelliPoint) Human Interface: Microsoft USB IntelliMouse Explorer 3.0 < Power Management > AC Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) < Network Services > Network Drivers Enabled: No filosofem
Aaron Mulqueen - 001 HD Native |
Re: Feature transfer error 7.3
So it's already solved the download problem? You can download the LE 7.3 file once purchased?
I think it's outrageous. If they're making it a paying upgrade, they should at least have it working well...
- Mac Pro 2.66 Quad 8GB RAM, PT 9.0.6 (OS X 10.6.7) |
Updated the PACE Interlok and away she went.
filosofem
Feature transfer error | criemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-11-2011 10:22 AM |
Feature transfer error | criemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-11-2011 10:17 AM |
feature transfer error during install | emiletich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-22-2010 04:03 PM |
Feature Transfer Error... HELP!!! | Funkle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-15-2010 06:35 PM |
trouble with installing protools8 (Feature Transfer Error) | mousetrapmarvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-30-2009 09:16 AM |
