Old 01-19-2011, 06:07 PM
B-Rob B-Rob is offline
Default PT Unable to Locate Mbox 2 Mini
On my Macbook Pro, Pro Tools 8 is "unable to locate" my Mbox 2 Mini. Digi Core Audio Manager says "Unsupported Device". The green LED does illuminate and Pro Tools 8 used to recognize it but now it does not.
Everything was working until I upgraded to Pro Tools 8.0.4 . I tried upgrading my OS from 10.5.8 to 10.5.8 (combo pack) to compensate. Tried PT uninstall and restart. Now Mbox Mini 2 has a demo mode that outputs beeps and white noise. Still no recognition from Digi software.
Will my Mbox 2 Mini ever work again?
Computer Specs:
Macbook Pro
OS X 10.5.8 (Leopard)
2 GB RAM
Old 01-19-2011, 06:10 PM
Default Re: PT Unable to Locate Mbox 2 Mini
Using Pro Tools LE by the way.
Old 01-23-2011, 08:59 PM
Default Katy Perry AVID
On my Macbook Pro, Pro Tools 8 LE is "unable to locate" my Mbox 2 Mini. Digi Core Audio Manager says "Unsupported Device". The green LED does illuminate and Pro Tools 8 used to recognize it but now it does not.
Computer Specs:
Macbook Pro
2 GB RAM
Old 01-23-2011, 09:04 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Katy Perry AVID
How does this relate to Katy Perry? Are you plugged directly into the computer or is it going through a hub? Plug it into the USB port closest to your power supply.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-23-2011, 09:25 PM
I'm not using hub. Tried both USB ports.. no dice. What now?
Old 01-23-2011, 09:33 PM
Dism Dism is offline
So wait... you uninstalled PT... did you reinstall it?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-23-2011, 09:52 PM
Yeah that's how I got the "unable to locate" error message.
Old 01-23-2011, 10:39 PM
Sparky1 Sparky1 is offline
I'm certain his problem is directly related to Katy Perry - might be too much - might be too little - tough to tell without more specs...
Sparky
Old 01-24-2011, 12:03 AM
I'm lazy so here's the paste from "About this Mac".
Model Name: MacBook Pro
Model Identifier: MacBookPro5,5
Processor Name: Intel Core 2 Duo
Processor Speed: 2.26 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP55.00AC.B03
SMC Version (system): 1.47f2
Serial Number (system): W89328XQ66D
Hardware UUID: 519C5F2E-83C5-5D8F-8B18-B86ED371124E
Sudden Motion Sensor:
State: Enabled
8.0.4 didn't work and 8 didn't work on the uninstall/restart. Should I try 8.0.3? 8.0.2?
Old 01-24-2011, 04:09 PM
Default Justin Bieber + AVID
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
State: Enabled
Pro Tools Express - Windows 8 - Unable to locate Hardware - Mbox Mini protoolsexpress Windows 1 02-15-2014 12:56 AM
MBox Mini UNABLE TO LOCATE HARDWARE Pro Tools Express electropunkboy macOS 4 11-18-2013 09:06 PM
PT10/Mbox Mini "Unable to locate hardware..." portrhombus Windows 3 12-21-2012 07:47 AM
Pro Tools Express unable to locate Mbox Mini at startup Dalyduo Pro Tools Express on Mac OS X 4 07-25-2012 08:23 AM
Unable to locate hardware. Mbox mini. Sears Pro Tools 10 10 03-12-2012 12:35 PM
