Multiple Interfaces
I just installed PT LE v7.4 + Digi 002r. I also have an MBox 2 that I would still like to use on occasion, but I can't get PT to recognize the MBox (runs fine with the 002 interface). Any suggestions? Thanks.
Re: Multiple Interfaces
bumping...
You weren't very descriptive, so are you saying you have them both connected simultaneously and PT won't see the mbox or that you disconnect the 002r and connect the mbox but PT won't see it, but PT will see the 002r when it is connected by itself?
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
Sorry about that.
I was trying to connect them at separate times, ie: open PT with only the Digi 002r, run a session, etc. And when need be, open a PT session with only the M-Box 2 plugged in. I tried the uninstall option when I upgraded to 7.4 (from 6.9) where the device drivers remain, meaning the 002r drivers were still on my computer, and then installing 7.4 with the M-Box plugged in. My hope was that both sets of drivers would then be on my system and I could run PT with either interface connected. But for whatever reason, probably something I did wrong, that didn't work. Hope that clarifies things. |
...double bump...
Figured it out,
contrary to what Digi says, I ran the Found New Hardware application (it came up automatically 4 times,one after the other) and all is well! I'm actually a little surprised that situation worked out. |
Multiple interfaces in pt9 HD? | muddboy | macOS | 7 | 05-12-2013 11:23 AM |
Multiple interfaces | Julia B | Pro Tools M-Powered (Win) | 3 | 06-22-2011 08:07 PM |
Multiple interfaces to PT9 | towelhead | macOS | 3 | 05-26-2011 10:18 AM |
Multiple Interfaces? | grimepoch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-01-2008 06:30 AM |
AES/EBU on multiple 96 interfaces | Robin Reumers | Pro Tools TDM Systems (Mac) | 0 | 10-12-2006 09:41 AM |
